Motor Flush
Old Mar 4, 2004 | 07:39 AM
int3gra's Avatar
Default Motor Flush
rtype11 suggested to me the Motul Engine Cleaner, i didnt want to travel to get it. He told me to put a capful in each spark plug hole and dump the rest in the oil and then change the oil right after.
Will this Gunk Motor Flush work the same way? I mean should i put a capful in each spark plug hole?
Modified by int3gra at 11:51 AM 3/4/2004
Old Mar 6, 2004 | 08:57 AM
rtype11's Avatar
Default Re: Motor Flush (int3gra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra &raquo;</TD></TR><TR><TD CLASS="quote">rtype11 suggested to me the Motul Engine Cleaner, i didnt want to travel to get it. He told me to put a capful in each spark plug hole and dump the rest in the oil and then change the oil right after.
Modified by int3gra at 11:51 AM 3/4/2004</TD></TR></TABLE>
could have just asked me - the details are a bit mixed up - if you decide to go the ATF route then a half capfull through the sparkplug hole then reinstall and run motor at idle then oil change. the motul engine cleaner for motorcycles/cars is added directly to engine oil then motor is run then oil change. I gave you a couple options off the top of my head, pls get the details.
just need to clarify before someone blows up a motor. cheers
1995Civiccx
Sep 21, 2007 02:19 PM
mongoliandonuts
Aug 27, 2004 11:51 PM
NickR
May 15, 2004 11:22 AM
H.crx-si
Jun 3, 2003 07:25 PM
sa21199
Jan 5, 2002 08:07 PM
