SMOKE??
Old Mar 4, 2004 | 01:30 PM
TOFU.man's Avatar
Default SMOKE??
I got into my car in 3rd gear today and a friend was behind me and he said there was some greyish white smoke normally that would mean running lean but How could i be running lean with when the A/F gauge is peggin the last green light and on a volt meter the o2 is reading .98 strong, can someone please explain this???
Old Mar 4, 2004 | 01:44 PM
birz's Avatar
Default Re: SMOKE?? (B16AHondaSi)
greyish is close to white IMO ,, maybe a leak in your head gasket, just a thought.
Old Mar 4, 2004 | 02:46 PM
TOFU.man's Avatar
Default Re: SMOKE?? (birz)
Nah not the head gasket.
Old Mar 4, 2004 | 02:49 PM
Bulldogg83's Avatar
maybe the air/fuel gauge is not reading correctly.....
Old Mar 4, 2004 | 02:56 PM
b16 matt's Avatar
Default Re: SMOKE?? (Bulldogg83)
mine does the same ****. i would also like to know what could be going on.
Old Mar 4, 2004 | 03:14 PM
InfamousGSR's Avatar
Default Re: SMOKE?? (b16matt)
Some guy that works as a acura tech said thats that normal for boosted cars. He said his WRX does it to. It depends how bad it is though.
Old Mar 4, 2004 | 03:33 PM
vtec.dc2's Avatar
are you burning/loosing oil or coolant?
Old Mar 4, 2004 | 06:24 PM
TOFU.man's Avatar
Default Re: SMOKE?? (vtec.dc2)
No im not buring oil or loosing coolant my oil looks brand new every time i change it and has the same amount as when i filled it up. I checked compression and the numbers are excellent. I just cant figure this out for the world. and as for the A/F gauge being off i know they are shitty thats why i taped the wire for the O2 sensor at the ecu and had a friend hold a voltmeter on it at WOT to check the voltage and it was holding .98 volts strong witch is about ideal air fuel ratio.
Old Mar 5, 2004 | 01:53 PM
TOFU.man's Avatar
bump
Old Mar 5, 2004 | 03:25 PM
b16 matt's Avatar
Bump
Old Mar 8, 2004 | 01:23 PM
b16 matt's Avatar
Mine is also not tuned.
40ray
Apr 14, 2011 01:55 AM
JDM_EK4_Coupe
Jun 26, 2007 10:28 AM
ericstambaugh07
Jun 24, 2007 07:49 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
Nocturnal
Oct 18, 2003 02:47 PM
