Precision Turbo Which model to chooose???
Old Mar 5, 2004 | 12:57 PM
WreckedTeggie's Avatar
Default Precision Turbo Which model to chooose???
Hey guys, im boosting my integra and i need help deciding on which turbo to use.
So far here is my set up
94 teg LS
b18c1 motor
Itr trans w lsd
3" exhuast
most likely 2.5" dp
etc
Im looking to be puttin down about 260 at first and increasing boost next winter to get 310 whp
It's my daily driver so i;m not looking for insane whp
Anyways, im deciding between the precision sc32, sc50 and sc 61 turbos.
Wat kind of setups/whp are you guys with these turbos getting? Also, about what rpms are you achieving full boost? Thanks alot guys, and any other pointers would be helpful.
Old Mar 5, 2004 | 01:23 PM
94gsr4dr's Avatar
Default Re: Precision Turbo Which model to chooose??? (ThatHondaGirl)
sc34
Old Mar 5, 2004 | 01:25 PM
MaxSterling's Avatar
sc34 for quick spool and 300whp at 12-14psi
sc61 for crazy whp
go sc34
Old Mar 5, 2004 | 01:31 PM
G
sh!t happens.
Default Re: Precision Turbo Which model to chooose??? (MaxSterling)
if you are wanting 310whp then get the sc34... its a good turbo i got it on my car and it spools good. if ya want more i would get the sc61...
sc34
Old Mar 5, 2004 | 01:56 PM
Trak_Day's Avatar
New User
I agree with them^^^^
SC34 would be a nice turbo for your setup! If you are looking for a turbo that will be nice and have potential to make alot more power later down the road the sc61 would be nice!
Old Mar 5, 2004 | 02:59 PM
fernancivic's Avatar
No Sales Forums
sc61..
Old Mar 5, 2004 | 04:08 PM
m R g S r's Avatar
Default Re: Precision Turbo Which model to chooose??? (CFT-Si)
I say go for the sc61. At 10 psi on a stock b18c, people have made almost 360whp, and they say it spools around 5k rpm's. Not too bad for the GSR motor, b/c it will rev to 8k.
Old Mar 5, 2004 | 04:09 PM
RyanEJ8's Avatar
Default Re: Precision Turbo Which model to chooose??? (94gsr4dr)
If his goal is only 310whp, why not just go with the SC50? It's efficient to around 400whp, which makes it perfect for your goals, its smaller and faster spooling and will still have some room to grow above your current goal if you change your mind.
My vote goes with the SC50 unless you want bigger numbers.
m R g S r's Avatar
Default Re: Precision Turbo Which model to chooose??? (m R g S r)
Ohh, and to get 260whp, you yould probally only need to run about 5-7psi on the sc61. Don't forget good engine managment
Old Mar 5, 2004 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote"> his goal is only 310whp</TD></TR></TABLE>
HERRRR I'm a girl thanks.
Old Mar 5, 2004 | 08:22 PM
Arturbo's Avatar
Better than steak
25 Year Member
Kate,
I would actually go with the SC50. The SC50 is a more effcient turbo and has the largest major diameter of all the T04E family. Its a fun set up and Ive seen 491whp at 30psi. So for your goals and a more "fun" set up I'd go with the SC50.
art
Old Mar 6, 2004 | 07:48 AM
RyanEJ8's Avatar
Default Re: Precision Turbo Which model to chooose??? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Kate,
art</TD></TR></TABLE>
Damn, what engine was te 491whp made on? I hear with the .48 A/R they are good to 400whp. I'm assuming this was done with the .63.
Old Mar 6, 2004 | 08:32 AM
mchuang's Avatar
Dam 491 on 30psi sucks ***. We have a b16 stock bore size puttin out 513 on 24 psi. Its a 1.8 liter though but still standard size bore.
Old Mar 6, 2004 | 09:10 AM
quikB18B's Avatar
Default Re: Precision Turbo Which model to chooose??? (mchuang)
Sc34 or Sc50. For your goals I would say the sc61 is a little overkill.
Old Mar 6, 2004 | 10:52 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang &raquo;</TD></TR><TR><TD CLASS="quote">
Dam 491 on 30psi sucks ***. We have a b16 stock bore size puttin out 513 on 24 psi. Its a 1.8 liter though but still standard size bore.</TD></TR></TABLE>
Not with an SC50 though! 491whp is alot on that size turbo and will spool very quickly. Turbo "A" might make 350whp at 20 psi with a FASTER spool and nice powerband, Turbo "B" might make 400whp at 20 psi with a slower spool and less usable powerband. I would probably take Turbo "A".
Old Mar 6, 2004 | 12:01 PM
Arturbo's Avatar
Better than steak
25 Year Member
But this was 5 years ago when there was no hondata, AEM or anything that you could plug in.
Old Mar 6, 2004 | 12:24 PM
Trak_Day's Avatar
New User
If anyone around here knows precision it is this man right here!
Old Mar 6, 2004 | 02:14 PM
bluebullet's Avatar
Default Re: (DroppedGSR)
sc50
Old Mar 6, 2004 | 02:22 PM
TurboJesse
Guest
Posts: n/a
Old Mar 6, 2004 | 02:35 PM
Matt@D2MRacing's Avatar
sc50 would be perfect for you setup
Old Mar 6, 2004 | 02:41 PM
Suprdave's Avatar
Default Re: (Matt@D2MRacing)
Lag is overrated
Just rev to 9,000...
Old Mar 6, 2004 | 03:50 PM
typer rick's Avatar
I thought the sc34 was good for 545 hp.
Old Mar 6, 2004 | 04:15 PM
Sonny's Avatar
SC50 from Art
Worked for me...got a good deal and even though my sister is now afraid of people with corn rows, it was worth it.
Sonny
asianeric
Apr 23, 2007 09:37 PM
Htounndea
Nov 11, 2006 06:43 PM
greasemonky50
Mar 15, 2006 04:40 AM
dk-fabrications
Oct 17, 2004 12:04 AM
tan2
Sep 3, 2003 06:40 PM
