Does 'clocking' turbo throw off ballance of turbo?
Old 03-05-2004, 08:21 AM
2000Accord5sp's Avatar
Default Does 'clocking' turbo throw off ballance of turbo?
I know many times people will rotate just the exhaust housing of a turbo...however, if you do that, internally wastegated turbo's will have the problem with the wastegate not lining up...specifically in my case, the wastegate is now on the complete opposite side.
So I was wondering if I can rotate both the hot and cold side to keep the wastegate in tact...basically you can also think of it as just rotating the center section so I can get the oil feed facing up (since this turbo will be mounted on top of the manifold) without having to get it ballanced afterwards.
I always figured the only part that needs ballancing is the fins so as long as you don't remove the fins physically from the center section, you won't be unballancing anything.
Old 03-05-2004, 08:41 AM
kpt4321's Avatar
As long as the wheels stay bolted to the shaft, you don't have to balance it.
Old 03-05-2004, 09:10 AM
b16ahybrid's Avatar
Default Re: (kpt4321)
And yes you can rotate the exhaust and compressor housings without rebalancing
Dan_the_MaN
10-05-2005 12:08 AM
AzntaggeR
04-28-2005 08:11 PM
B20-T
07-28-2002 12:39 AM
Quick Reply: Does 'clocking' turbo throw off ballance of turbo?
