Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains?
Old 03-02-2004, 09:59 AM
Spooled1.6L's Avatar
Default Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains?
Iv seen boostfed's gains and they are very impressive but thats also at higher boost, Im just wondering if anyone has any experience with this at lower boost level like 7 psi or so. Just wondering what kind of gains
Old 03-05-2004, 04:23 PM
markaria's Avatar
Default Re: Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains? (Spooled1.6L)
I have a b16 with a itr head and ctr cams and got 216whp @7psi on a mustang dyno. I however have never had stock b16 cams to compare with...hope this helped
Old 03-05-2004, 04:47 PM
Default Re: Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains? (markaria)
have you run the car? because I feel like my car would have more hp then that with just the b16. But I guess I dont really know
Old 03-05-2004, 05:43 PM
On Fire!
Adi Radoncic's Avatar
https://honda-tech.com/zerothread?id=704660
Old 03-15-2004, 06:08 PM
markaria's Avatar
havent run it yet, but from what I understand 215 hp on a mustand dyno is closer to 235 on a dyno jet. The car feels great, it pulls strong to redline...I wish I knew how to post my dyno chart...
Old 03-15-2004, 07:43 PM
slrh22hatch's Avatar
I've heard you should never use ctr cams on a turbo car.
Old 03-15-2004, 09:57 PM
TurboJesse
Guest
Posts: n/a
Default Re: Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains? (slrh22hatch)
i would do other things than cams if your only gonna run 7psi, I made over 250whp with stock b16a cams @ 7psi.
Old 03-16-2004, 12:23 AM
importboi22's Avatar
Default Re: Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains? (Mpir3)
ya i've seen the thread about ITR cams suck for boost thread.... ill put it this way... if your making 500hp then ya GSR cams will prolly be holding you back, but for the average street setup, your gonna be most likely better off with GSR cams
Old 03-16-2004, 12:36 AM
liam821's Avatar
Default Re: Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains? (importboi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importboi22 &raquo;</TD></TR><TR><TD CLASS="quote">ya i've seen the thread about ITR cams suck for boost thread.... ill put it this way... if your making 500hp then ya GSR cams will prolly be holding you back, but for the average street setup, your gonna be most likely better off with GSR cams</TD></TR></TABLE>
Almost all of the 8 and 9 second hondas run GSR cams. Ive seen 700+ whp on gsr cams.
liam
Old 03-16-2004, 02:57 PM
Default Re: Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains? (liam821)
IM looking at trying to get a 450whp b16 thats about the extent of my goals. Im not sure if I should just go with GSRs or head for the type Rs
Old 03-16-2004, 03:06 PM
drvfast's Avatar
go with the gsr cams they are cheaper and work great with boost
jspeccrx91
05-12-2010 06:41 AM
elektronsi
04-29-2008 06:33 PM
hellakapps
10-18-2007 01:05 PM
keebler65
03-25-2003 03:25 PM
SuperCivic
19
06-28-2002 07:09 PM
Quick Reply: Anyone with a Turbo b16 upgrade to Type R cams at Low boost leves? What gains?
