headgasket for boost?
Old Mar 2, 2004 | 09:58 PM
iwouldHITit's Avatar
Default headgasket for boost?
are NAPA headgasket stong enough for boost??im running 6-9psi....i looked at NAPAs gasket and looks pretty good 3layers of metal...cause i dont want to pay $200 at the dealer
do all LS motor use the same gasket??
Old Mar 2, 2004 | 09:59 PM
JDMorgan's Avatar
i thought oem was 80?
EDIT: I was wrnog....acuraparts.net
HEAD GASKET, Integra - GS-R, TYPE R 94-01 $58.82
HEAD GASKET, Integra - RS, LS, GS 96-01 $58.82
Old Mar 2, 2004 | 10:12 PM
99B16Si's Avatar
i got my b20 headgasket sraight from the deal for $51
your being had by whoever your going to (maybe he meant a gasket set???)
Old Mar 2, 2004 | 10:19 PM
rocket256's Avatar
Default Re: headgasket for boost? (iwouldHITit)
Just use your stock one and you should be fine
Old Mar 2, 2004 | 10:41 PM
XSIintegra's Avatar
Default Re: headgasket for boost? (rocket256)
If you blow out a 3-layer, either your boosting a LOT or something else is wrong, ie warped head, weak head bolts.
Old Mar 2, 2004 | 10:42 PM
99B16Si's Avatar
all ls headgaskets are the same but i think the oil passage diameters may be slighly different from the newer to the older...either way it doesnt matter which one u use theyll both work with zero problems
Old Mar 2, 2004 | 11:07 PM
JDMorgan's Avatar
hey i was just thinking its around 150-200 for the whole top end gasket kit right? maybe thats what the price was for? i know i went to buy the valve cover gasket at autozone and the thing costs more than from the dealer normal price. i only use the 25% on big stuff cuz it takes a day to get normally. i normally need that **** that day. of course im gonna use it when i get the oem top and bottem end gasket kit with bearings and itr vc cuz ill prolly save a bill.
krazych0p
Nov 10, 2008 01:38 PM
teddy_dc2
Jun 29, 2006 05:28 PM
92lsvteceg6
Nov 7, 2005 05:16 PM
ThirdGenLSR209
Jun 12, 2004 04:50 PM
zCivic
Jan 11, 2003 12:35 PM
