Problem with my BOV
Old Mar 2, 2004 | 02:27 PM
turbocivic96's Avatar
Default Problem with my BOV...you tell me!!
I have a 1st gen eclipse BOV on my civic and i am not sure if it is working correctly. When im at idle the BOV is open. When i rev the engine a bit it closes but does NOT stay closed. I do not have a vaccuum leak and i believe it has been crushed. IS this the way it is supposed to be or is it a POS. I have not driven the car yet because im an still putting the kit together. Any info would be greatly appreciated. Heres a pic so you know which one im talking about,NOT my actual one but jsut as an idea.
Modified by turbocivic96 at 6:52 PM 3/2/2004
Old Mar 2, 2004 | 03:58 PM
Ri5e's Avatar
Default Re: Problem with my BOV...you tell me!! (turbocivic96)
My Greddy Type S does that and so does a couple of friends.
Under vacuum the valve opens up to release the pressure
Once you put load on the engine, the valve closes
Old Mar 2, 2004 | 04:00 PM
blown_LS's Avatar
Default Re: Problem with my BOV...you tell me!! (2URBO)
Yes that is perfectly normal. If you crush it then it will stay shut at idle.
honda_fan06
Mar 15, 2009 07:12 PM
92CHB
Jun 4, 2005 01:47 PM
NotUrAvgSi
Sep 14, 2004 10:37 AM
Trigun
Nov 30, 2002 02:19 PM
Aeka GSR
Jun 11, 2002 07:34 PM
