Resistors or OEM Resistor Box?
Old Mar 2, 2004 | 03:48 PM
warwagon's Avatar
Default Resistors or OEM Resistor Box?
I have 4 10ohm 10watt resistors for my injectors and was just wondering if it makes a diff to use those or a stock resistor box
thanks
Old Mar 2, 2004 | 03:57 PM
Mad Cow's Avatar
Default Re: Resistors or OEM Resistor Box? (warwagon)
I tried the radioshack resistors twice, to no avail. OEM resistor box worked first time.
Haberdasher's Avatar
They do the same thing. The only difference is that the resistor box is a cleaner install and looks stock if you do a good job.
Old Mar 2, 2004 | 04:07 PM
warwagon's Avatar
Default Re: Resistors or OEM Resistor Box? (MadCow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow &raquo;</TD></TR><TR><TD CLASS="quote">I tried the radioshack resistors twice, to no avail. OEM resistor box worked first time.</TD></TR></TABLE>
what you mean madcow uberdata user? to no avail.?
Old Mar 2, 2004 | 04:37 PM
tegmech's Avatar
he means they didn't work
Old Mar 2, 2004 | 04:38 PM
warwagon's Avatar
ahh anybody else have probs with them
Old Mar 2, 2004 | 04:44 PM
Burke's Avatar
Banned
Default Re: (warwagon)
i used some 1watt resistors once. melted one doing a burnout. still ran a 14.0 on 3 cylinders
just use atleast 5 watt ones and you will be cool
Old Mar 2, 2004 | 04:54 PM
StrikeAnywhere's Avatar
10W 10ohm resistors. cut the yellow/black wire off the injector clip and solder the resistor right in.
Old Mar 2, 2004 | 06:19 PM
Mad Cow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">
what you mean madcow uberdata user? to no avail.?</TD></TR></TABLE>
warwagon, uberdata user, they didn't work. I got Code 0 from the ECU. I had the soldered inline with the black/yellow resistor wires. In the end, I just said got a resistor box and it's worked ever since.
Old Mar 2, 2004 | 08:34 PM
warwagon's Avatar
cool then i will do the same if my resistors fail me
avotegra
Apr 6, 2007 11:57 PM
Whiteintegra
Jul 15, 2006 11:02 AM
guywitaDA
Dec 7, 2004 07:08 PM
z6
Jun 19, 2004 06:37 PM
