Has anyone had this Turbo Timer problem...
Old Mar 5, 2004 | 01:07 AM
eg_nezay's Avatar
Default Has anyone had this Turbo Timer problem...
I recently relocated my Turbo Timer (that means I unplugged and plugged it back in)
Now, I read the lil instruction book that comes with it, over and over and I cant seem to troubleshoot the problem.
Here is the problem, everytime I shut off the car, the TT shuts off aswell. Even though the [a] is displayed for auto. It should do its count down but it doesnt.
Any help will be appreciated
Old Mar 5, 2004 | 01:10 AM
GSRrR's Avatar
Default Re: Has anyone had this Turbo Timer problem... (eg_nezay)
i had that problem. check your connections, 1 of mine came loose.
Old Mar 5, 2004 | 01:15 AM
eg_nezay's Avatar
Default Re: Has anyone had this Turbo Timer problem... (GSRrR)
Ok, will do, did your TT have any other problems because of that bad connection?
Or was it only the countdown like mine?
Im also using T connectors so I dont see how it would be loose.
Specially after I made sure I didnt pull hard to disconnect anything.
Old Mar 5, 2004 | 01:27 AM
GSRrR's Avatar
it just would not count down like you said. it turns on with the car, but when i turn the key to take it out, the timer just turns off instead of counting down. i have the greddy timer. check the ground too. HTH
Old Mar 5, 2004 | 01:44 AM
eg_nezay's Avatar
Thanks, will do
Etorres325
Mar 31, 2010 05:30 PM
russuk_96jdm
Aug 31, 2007 10:33 AM
importracer3
Dec 5, 2005 07:30 PM
Xbstd23X
Jul 23, 2004 01:28 AM
