oil return angle ok?? pic
Old Mar 4, 2004 | 07:42 PM
dunkd's Avatar
Default oil return angle ok?? pic
i believe this is where the oil fitting has to be welded? am i right, if so is this angle ok?
Old Mar 4, 2004 | 07:44 PM
GSRrR's Avatar
Default Re: oil return angle ok?? pic (dunkd)
the dip that the line creates is not good. you can get those 45* fittings.
Old Mar 4, 2004 | 07:46 PM
dunkd's Avatar
Default Re: oil return angle ok?? pic (GSRrR)
you say not good, what will happen?
Old Mar 4, 2004 | 08:06 PM
BSeriesTurbo's Avatar
oil will tend to kinda puddle and won't flow back into the pan as well..and also I believe you might want it up a little higher on the pan itself..
Old Mar 4, 2004 | 08:10 PM
rondigs's Avatar
Default Re: (BSeriesTurbo)
45 degree fitting would make it
Old Mar 4, 2004 | 08:13 PM
ek9vboi2's Avatar
i dont see a diff. my oil line goes lower then that and no diff.
Old Mar 4, 2004 | 08:55 PM
m R g S r's Avatar
Default Re: (SoHc10Lbs)
I'm not sure if it was b/c of my oil return, or my seals just were shot, but my turbo started to spit reallllly smalll amountsd of oil out of the inlet. BTW, my oil return looked like that.
Old Mar 4, 2004 | 09:02 PM
MikeMAN's Avatar
2 45 degree fittings would be ideal...have a nice 45 degree downward slope into the pan...but 1 would suffice..
mike
Old Mar 4, 2004 | 09:58 PM
5thgencivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRrR &raquo;</TD></TR><TR><TD CLASS="quote">the dip that the line creates is not good. you can get those 45* fittings.</TD></TR></TABLE>
As long as the turbo drain flange is above the oil pan fitting(and the pan fitting is above oil level) there is no harm with a little dip like that. Oil will sit in the line at that spot, but it will not back up. My $.02
Old Mar 5, 2004 | 06:01 AM
mike1114's Avatar
Default Re: oil return angle ok?? pic (5thgencivic)
seriously, get two 45 degree fittings. You will eventually blow your turbo seals. Especially if your going down a hill, oil could back up in the line at that angle. Mine looked like yours during the install so I switched to a 45 degree fitting at each end and have never had a problem.
Old Mar 5, 2004 | 07:19 AM
Cruiser G's Avatar
Default Re: oil return angle ok?? pic (mike1114)
yea, just get a 45 and put it on the turbo flange then shorten the line up a bit.
Old Mar 5, 2004 | 07:25 AM
dunkd's Avatar
the 45 you guys are talking about is the one that stan sells for like 20$?
Old Mar 5, 2004 | 08:21 AM
1bad-eg's Avatar
Default Re: (dunkd)
Yes, hit Stan up, he should be able to help you. He helped me.
Old Mar 5, 2004 | 09:30 AM
JrCRXHF's Avatar
Default Re: oil return angle ok?? pic (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">2 45 degree fittings would be ideal...have a nice 45 degree downward slope into the pan...but 1 would suffice..
mike</TD></TR></TABLE>
Old Mar 5, 2004 | 09:54 AM
Flamenco-T's Avatar
Default Re: (dunkd)
a 45 degree angled hose end would be your best solutions. I think you will be okay with -8AN line, but you erally relaly have to make sure that the line are in downward path since it flows less than a -10AN hose.
stan
jprelude92
Aug 30, 2008 07:12 AM
SM00TH976
May 17, 2006 08:59 AM
moesrex
Apr 3, 2006 07:35 PM
hackish
May 17, 2004 09:45 AM
GruvyTune
Nov 18, 2001 03:59 PM
