Dyno'd Today...
Old Mar 3, 2004 | 12:05 AM
b18c1civic95's Avatar
Default Dyno'd Today...
Okay im kinda dissappointed! maybe i shouldn't be. Okay I have a 98 Gs-r obd-1 ecu in a 95 vx.
(dyno'd)CAI/H/E 150 whp and a best of 14.1 1/4 before turbo.
went to the dyno today and it put down 196.6HP/152.3TQ
This was done at 8 psi. the guy asked if my plugs were done but i told him i hadn't made the gap smaller. I'm getting the plugs tomorrow. He said like .035??
He said he could feel it hesitating a little bit. he said it pretty much blows out the fire lol. So this hesitating i feel sometimes could be the spark being boosted away right lol? It drops about 6 hp at the first part of v-tec and a few more than 6 on the second part at 5800. i wish i could post the sheet. But all in all i guess its not to bad for a stock drag kit which im beginning to hate more and more each day i look in the engine bay.
Old Mar 3, 2004 | 12:43 AM
R6Elmo's Avatar
Default Re: Dyno'd Today... (b18c1civic95)
try gapping them around 0.030 or so. Good luck
Old Mar 3, 2004 | 02:19 AM
pissedoffsol's Avatar
25 Year Member
Default Re: Dyno'd Today... (R6Elmo)
drag kits suck y0!
but seriously, get the right plugs.
NGK stock # 5238 ... R5671A-9
or 1 step warmer (those are pretty cold.. higher power cars)
and think about upgrading the fmu to something better.
Old Mar 3, 2004 | 03:27 AM
BoostedD15B7's Avatar
pissedoffsol...
are those colder than the brk7e plugs?
Old Mar 3, 2004 | 04:28 AM
RedTegLS's Avatar
Default Re: (BoostedD15B7)
Those numbers do seem a little low. I have an LS and look at my numbers. That was on a waterbreak dyno too. What is your complete setup?
Old Mar 3, 2004 | 06:59 AM
GDM Z28's Avatar
Default Re: (RedTegLS)
what stage kit do you have? what turbo? i know a guy on here that made 293whp on 10 psi with a revhard kit i think it is. those numbers dont sound 2 good. on 6 psi he made 244. and on 10 psi on my ls i made 242. hows your compression? check your plugs. dont get the 9 series get the 11 series. check out http://www.clubplug.net
Old Mar 3, 2004 | 07:26 AM
SpoolnG2's Avatar
Default Re: (civicflnum1)
A question that should have first been asked, what kind of dyno was this done on? MD, Dynojet, Dynapack ? Also, what size exhaust do you have?
Old Mar 3, 2004 | 07:36 AM
PrecisionH23a's Avatar
Run the NGK 3330's gapped to .030 as said earlier.
You'll be very impressed by the gains you'll receive.
Old Mar 3, 2004 | 07:49 AM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 &raquo;</TD></TR><TR><TD CLASS="quote">pissedoffsol...
are those colder than the brk7e plugs?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=510127
Old Mar 3, 2004 | 08:01 AM
Rory Breaker's Avatar
Why do you hate your Drag kit? Get the setup together the right way, then lets see what you do!
Old Mar 3, 2004 | 08:09 AM
99B16Si's Avatar
Default Re: Dyno'd Today... (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">drag kits suck y0!
DO Not run that plug, it is WAY too cold for your application. your car will run like **** in boost and especially out of boost. go with a n NGK BKR7E-11 gapped to about .028. the only way youll ever need a 9series plug will be if your pushing upwards of 500hp.
PS your numbers are WAY off. no need to look at HP, just look at the torque. your torque should be at about 180wtq. check for leaks in your IC piping and exhaust before the turbo. also a compression test may be necessary but hopefully not. goodluck
Old Mar 3, 2004 | 08:13 AM
ladysman's Avatar
Default Re: (pissedoffsol)
https://honda-tech.com/zerothread?id=510127</TD></TR></TABLE>
Wow, I feel special again.
8 or 9 series plugs are too cold for 8 psi. Use the 3330's or BKR7's as stated above. Gap at .030 with stock ignition and .035 with MSD (or equivalent). These are guidelines I follow.
Good luck and keep us posted.
Old Mar 3, 2004 | 08:17 AM
ineedhelp's Avatar
you did a lot better then me when i first had it on my gsr...pulled about 187whp and aboput 150lb tq. on a mustang dyno. i was new to turbo, and expected gains of 250+ just like you did, and was pissed just as much as you are. but at the time now that i think of it..a lot of the things i had on the car was half-***.
eventually it will get better...my last dyno i made 270whp and 190 &lt;~~~still with the drag kit and a 2.5 exhaust. so theres hope for you. dont give up.
dont hate on your car or the the drag kit it has...everything isnt going to be perfect the first time around.
Old Mar 4, 2004 | 01:25 AM
Default Re: Dyno'd Today... (ineedhelp)
hey thanks for the replys everyone. my complete setup is drag-3 t3 turbo kit.2.25 exhaust, blitz bov, delta wastegate, the blue FMU (VORTECH?) msd blaster ss coil. 8.5 mm plug wires. One important thing is there is no exhaust gasket at the manifold. the boost gauge was reading 8 psi. i bought a vaccum box because i was having problems with my bov vaccum line. havent installed that yet. I also have skunk2 turbo cams, valves, springs and retainers for install soon. anywayz i was anxious to get my car cuz its my only one now. Im not as dissapointed as i come across. i think I let my car down lol. so its safe to say the ngks would be best right?? what kinda numbers should i see for compression?? hey thanx for the encouragement *ineedhelp* and everyone else. im gonna try and post this dyno sheet now. i will also post times from this coming saturday if the new launch pad is done at the track.
Modified by b18c1civic95 at 3:23 AM 3/4/2004
Old Mar 4, 2004 | 03:49 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Dyno'd Today... (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">
go with a n NGK BKR7E-11 gapped to about .028. </TD></TR></TABLE>
this will help alot , and i didnt see you mention it in your first post , did you do a compression test????
Old Mar 4, 2004 | 04:57 AM
RedTegLS's Avatar
Default Re: Dyno'd Today... (Hella_JDM)
A 3" exhaust would put you closer to 210 maybe 215. I didnt see if you had bigger injectors. Or are they not needed becuase of the FMU. I say sell that FMU, buy some RC550's, and get a custom ECU or hondata.
Old Mar 4, 2004 | 05:27 AM
hulkhb's Avatar
Well now i see the problem, you went to turbo tech,
ditch the fmu and plugs should run alot better. If you need any help on anything i am local so hit me up.
Old Mar 4, 2004 | 10:13 PM
Default Re: Dyno'd Today... (hulkhb)
Nice to hear from someone locaL.wANNA HELP WIRE UP A JDM H23 V-TEC LOL. No i havent ran a compression test yet, Im very curious as to what that would turn out to be, been thinkin about it lately. Hey hulk what kind of dyno is that at turbo tech?? where do u go for tuning around here?? oh and nice pics!! I'd like to see that at the track this year. thanks again guys. oh and red teg no i dont have bigger injectors. my buddy said he could get me some dsm ones for very cheap. from his mitsu tuner. he said the exact thing you did.
Modified by b18c1civic95 at 11:40 PM 3/4/2004
Old Mar 5, 2004 | 03:57 PM
IEATLINT's Avatar
im going to Carb & Fuel Injection Connection (DynoJet) up in Kirkland to tune my Hondata. Intec Racing in Kent also has a Dynojet. oh btw im not sure if you know or not but if you get yourself dsm 440's your going to have to get a resister box from a ef civic or crx. they're pretty cheap though from what i understand. good luck
Old Mar 5, 2004 | 06:47 PM
HXMan's Avatar
You can make good power with drag kits....
Old Mar 5, 2004 | 09:47 PM
Mr. Softee's Avatar
Default Re: Dyno'd Today... (HXMan)
when you redyno run open downpipe.
also what fuel mgmt
Old Mar 5, 2004 | 11:12 PM
oh thats good to know. I didnt know i needed a resistor box for the 440's. man i really need one of those for my girls h23!! how much does hondata run? any place local that carries it? Ive seen them show up now and again in the classifieds here but never had a need back then. oh and i dont have any aftermarket fuel management. just the boost dependant fmu that came with the kit.
Old Mar 6, 2004 | 07:05 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1civic95 &raquo;</TD></TR><TR><TD CLASS="quote">oh thats good to know. I didnt know i needed a resistor box for the 440's. man i really need one of those for my girls h23!! how much does hondata run? any place local that carries it? Ive seen them show up now and again in the classifieds here but never had a need back then. oh and i dont have any aftermarket fuel management. just the boost dependant fmu that came with the kit.</TD></TR></TABLE>
http://www.hondata.com
Ditch the FMU and get some injectors and the Hondata. The engine will make more power and run safer.
Old Mar 6, 2004 | 08:19 AM
VTC_CiViC's Avatar
Default Re: Dyno'd Today... (ladysman)
BCPR7 or BKPR7, gapped to .030. If you don't dyno at least 220whp +/- 10whp @8psi, something is wrong.
Old Mar 6, 2004 | 08:25 AM
quikB18B's Avatar
Default Re: Dyno'd Today... (VTC_CiViC)
I keep seeing people say get rid of the fmu, and god knows I agree with them, but the point is there is a problem right now the way the car sits.
A gsr with basic kit, fmu 7-8 psi should make Atleast 230-260 granted its a Revhard/Drag kit.
My suggestion is yes upgrade your fuel system, but before you do Find out what is the problem in your setup.
It's been asked, but I dont think its been answered. What kind of Dyno?
