Question about greddy setup??
Old Mar 3, 2004 | 06:09 AM
Chillinit's Avatar
Default Question about greddy setup??
I have a greddy kit for my gsr....its an 18g. My question is, given that my 18g has an internal wastegate...do I need a mbc to run from the wastegate to the vacuum source or is it the wastegate threaded arm that dictates the about of boost that will be run?? please help..
Old Mar 3, 2004 | 08:01 AM
pissedoffsol's Avatar
25 Year Member
Default Re: Question about greddy setup?? (Chillinit)
internal wastegates are pre-set for X psi. if you want more, you can run the boost controller. if not, you don't need one.
Old Mar 3, 2004 | 09:54 AM
shadow103rd's Avatar
Ive also heard that on internal wastegated turbo, there is an adjustment on the actuator arm......you just use the set screw or whatever it is to move it out or in and you can get more boost that way....someone correct me
Nisif
Jun 26, 2013 11:20 AM
Strokin4dr
Jun 12, 2007 01:28 PM
Blazin Civic
Mar 7, 2005 10:49 PM
BDTURBO
Nov 5, 2004 08:05 PM
GreddySi99
Jul 9, 2003 10:29 AM
