Question about the safc-2 tuning i can do b16a 15g turbo
Ok, heres my set up
b16a jdm pr3
greddy sohc 15g turbo kit running dsm smic
2.5" exhaust.
stock timing, stock plugs,
msd 8mm wires with sci igniton
walbro 255 pump
10:1 vortech fmu
home made mbc running 8 psi
heres my question, i was going to throw in some 450cc injectors here real soon, ditch the fmu, and run the hack, but i gotta wait a bit. Can i tune my car with just throwing on the safc 2 and not having to worry about changing injectors just yet?
my biggest concern is everyone is telling me that my car will get ALOT of advanced timing, but i am not running the hack yet. so is this true? basically the setup will be fmu, fuel pump stock injectors and safc 2.
also does anyone have the pr3 ecu pinout? i need it to wire in my safc 2. thanks everyone.
and yes i will go uberdata eventually. its just not an option at this time, with obd o. thanks everyone!
b16a jdm pr3
2.5" exhaust.
walbro 255 pump
10:1 vortech fmu
New User
Re: Question about the safc-2 tuning i can do b16a 15g turbo (stolencrx)
well i have a 15g in a b18b, i'm running the SMC+ DSM 450 hack may i ask what mbc you are using cause i can't get it to hold 8psi home-made as in which style? got a link?
Re: Question about the safc-2 tuning i can do b16a 15g turbo (integrx)
its the home depot style one. the boost isint really my concern right now though. the problem with my car is i stuck in the 450cc injectors, i took off the check valves and fmu, and put on the safc 2. the car is so rich it spits out raw gas. i even leaned it out to -50. anyone else have this problem or know what it might be? thanks guys!!
Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax »</TD></TR><TR><TD CLASS="quote">DSM injectors? are you runnin a resistor?</TD></TR></TABLE>
91 crx si. stock resistor box
anyone?
anyone?
Re: (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">6 in 6 out?</TD></TR></TABLE>
yes sir.
yes sir.
bumsta217
05-04-2005 10:24 AM
boostincoupe
10-06-2003 06:53 AM
