2 quick wastegate questions...
1. does anyone know if a Deltagate 9psi spring will fit in a Tial 38mm?? I can't really see how the springs could be that much different based on brand
2. I have a 3.5lb spring in my Tial currently...if I kept the 3.5lb spring in there and turned the bc up to 10lbs, would there be any adverse effects on the spring or wastgate assembly?? would I be trying to stretch this too much??
basically instead of putting the 9psi spring in there from friends deltagate, am I fine with the 3.5lb spring and just upping the boost controller to 10lb..thanks for any input
JDM turbo DC
Jan 29, 2006 06:20 PM
