Help me decide between a sidewinder or inlinepro cast
Old Aug 22, 2004 | 08:48 AM
Keith P's Avatar
Default Help me decide between a sidewinder or inlinepro cast
ok, need to make a quick decision...
91 hb, b16, tial 38mm, t3/t4e.. shooting for low low 400hp level
should I get a inlinepro cast. or a welded sidewinder... the inline pro will be a simple bolt on. where as the sidewinder will be a bit of a challange, including tryin to fit the 38mm tial in the 40 flange, etc..
my fear is that the sidewinder may never fit well. I also worry that the inlinepro won't flow as well as the sidewinder..
(P.S. I need to fit a full size aluminum radiator!)
I'll let H-T decide!
Old Aug 22, 2004 | 09:13 AM
lonnieboost's Avatar
Default Re: Help me decide between a sidewinder or inlinepro cast (Keith P)
Where did you get the idea that inline pro would not flow as well? I used it before and worked great for me. There are many others on this board as well who can share the same feelings as I do. check Arturbo he will give you some insight on this.
Old Aug 22, 2004 | 10:04 AM
11psiTurboSI's Avatar
Default Re: Help me decide between a sidewinder or inlinepro cast (lonnieboost)
I just got a InlinePro manifold and I have to say it made a world of difference then my DRAG manifold... people made 500+hp on them, no problem so it should meet your power goals easy!
Old Aug 22, 2004 | 11:48 AM
project dc2's Avatar
Default Re: Help me decide between a sidewinder or inlinepro cast (9psiTurboSI)
redzoneperformance and i will be holding a groupbuy for the new blox cast turbo manifold, ac compatible, lifetime warranty soon. 350 shipped if we get 10 people into the groupbuy. shoudl be up within a week. ill also be offering ic pipng and downpipes for them.
Old Aug 23, 2004 | 06:21 AM
JonnyCoupe's Avatar
Default Re: Help me decide between a sidewinder or inlinepro cast (project dc2)
I posted on a thread regarding teh blox manifolds then when i came back online later to check for more replies and discussion on what i think look very promising manifolds it had been moved to mod's corner.
Jonny
Old Aug 23, 2004 | 06:36 AM
-Trinitron-'s Avatar
I personally chose the inline pro. There are a lot of people using it to make big numbers. The sidewinder is a DOPE *** manifold, but there is a lot of custom work that has to be done, like replumbing radiator lines and different charge piping routes. I would love to have a sidewinder, I just couldn't afford the manifold or the downtime it would have taken to get it right.
Old Aug 23, 2004 | 06:39 AM
Tinker219's Avatar
Default Re: (-TRINiTRON-)
The SideWinder is pretty much an "in shop" only manifold now. Unless the buyer TRULY understands what has to be done in order to accomodate this manifold.
Im going to suggest the AC Mini-me. 3" DP can be used w/ease(provided you go to a half radiator). And its only a touch more than the Inline Pro. Performance should match/exceed that of the inline because of the collector and wastegate placement.
davidluko
Mar 3, 2007 09:32 PM
Yambor
Welding / Fabrication
Feb 22, 2007 03:22 PM
Importracer_001
Dec 15, 2005 03:13 PM
jiggy
Jan 18, 2005 09:16 AM
B18 CYA
Jun 1, 2004 02:25 PM
