B16 or B18 for boost...
Old Aug 21, 2004 | 07:59 AM
94hatcheg04's Avatar
Default Wuts Better 2 Boost?
I have a 94 hatch. I was wondering wut is a better swap a B16 or a B18. Cause i also wanna boost so wut would be better?
Old Aug 21, 2004 | 08:11 AM
menkio's Avatar
Default Re: Wuts Better 2 Boost? (94hatcheg04)
b18 yo
Old Aug 21, 2004 | 08:46 AM
jman30513's Avatar
Default Re: Wuts Better 2 Boost? (DewMota)
do a mini me in your car anf turbo it
done
oh yeah get an si or ex tranny
jman
Old Aug 21, 2004 | 08:48 AM
KarbinFourteen's Avatar
Default Re: Wuts Better 2 Boost? (jman30513)
where can one find si/ex tranny for cheap?
do they really make a big difference, i have d15b7 bblock
what is tranny code for si/ex?
Old Aug 21, 2004 | 09:02 AM
ecahatch's Avatar
Senor Miembro
LS
Old Aug 21, 2004 | 09:50 AM
3.point.2's Avatar
you can run into problems turboing those two if you dont change to some lower compression pistons. but i would do b18.
Old Aug 21, 2004 | 10:13 AM
T S R Performance's Avatar
Default Re: (h23eg)
do LS turbo for everyday driving, you can push about 10lbs on a stock LS block. do 7 for everyday driving though. alot safer, a lot cheaper, and more torque
Old Aug 21, 2004 | 10:16 AM
jman30513's Avatar
running 8 psi on my d16y8 tuned with uber...
199whp 176wtq
cost me 1500 to get there
a swap aint even gonna get you that close
oh yeah....stock bottom
do what you like though...im just trying to show you what you can do with what you have already
jman
Old Aug 22, 2004 | 10:02 AM
HondaIntegraGSR's Avatar
Default Re: (jman30513)
ls better tranny for it longer gears and it is a stronger engine for it
Old Aug 22, 2004 | 10:08 AM
Ricey McRicerton's Avatar
Default Re: (HondaIntegraGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIntegraGSR &raquo;</TD></TR><TR><TD CLASS="quote">ls better tranny for it longer gears and it is a stronger engine for it </TD></TR></TABLE>
Longer gears arent good for **** except for good gas mileage. Staying in boost does you no good. Shorter gears are good for accelleration. Period.
Old Aug 22, 2004 | 10:12 AM
Default Re: (Ricey McRicerton)
hmmmmmmm
Old Aug 22, 2004 | 10:49 AM
donkiman's Avatar
b18. i think b16's on 9 psi generally see around 250whp. i saw 290whp with my b18c1 on 9psi with hondata. no replacement for displacement
Old Aug 22, 2004 | 11:51 AM
Sohc Driver's Avatar
Default Re: (donkiman)
259whp/211wtq @ 10.5psi on an LS here.
Khoi
Old Aug 22, 2004 | 12:23 PM
jaM3s Bond's Avatar
Default Re: (Sohc Driver)
Pound for pound the b16a will make more power per PSI.
The LS will add a very small bit of safety, but the b16a is a better turbo motor. Better flowing head, oil squirters and so fourth.
Turbo is a power ADDER. the more power you start with, the more power you get.
Old Aug 23, 2004 | 04:15 AM
jman30513's Avatar
210whp and 185wtq
d series
all i paid for was the turbo and this is on stock internals....1k gives me all the internals i need to get 250-300whp and then im only in for 2k (includes turbo setup)
thats still 1k under any nice b-series swaps (and not even got a turbo yet)....guys i dont hate b-series by any chance....ive had 4 swaps in 4 cars totalling me over 3k on each one and could never afford a turbo...im just trying to so him the cheapest route to good power
jman
Old Aug 23, 2004 | 04:46 AM
jerbear!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jman30513 &raquo;</TD></TR><TR><TD CLASS="quote">
jman</TD></TR></TABLE>
thats so true
Old Aug 23, 2004 | 05:39 AM
murmur9's Avatar
Default Re: (jerbear!)
if you like the BOV sound (like me) urbo your D series...i agree with that one guy. do a mini me....its super east to do a swap with another d series....(for your first time) the other ones are a bit diff. for your first time putting in a motor.
But out of a b16 and b18. i would be the 1.8L lol more torque. Torque is what you feel...its that diff. why pay all that **** for a b16 when you feel the same as a d series...get that extra .2 L and get some torque. b18 non vtec would be nice. higher compression i believe...right ?
Old Aug 23, 2004 | 07:21 AM
blackeg's Avatar
Default Re: (murmur9)
b18b y0! on 8 psi it should put out around 225 or so hp, and be very safe and reliable. a d16 will be on its limits at 225 whp. and then if you want to up the boost, the ls can handle 250+ on stock block and stuff very well with a resonable tune on it. the b16 will put down low torque #'s and is prone the the broken ringland syndrome(as are most honda's, but anyway). put it this way- i had a turbo d16, and to avoid any headaches and worries about blowing my **** up at like a little over 200 whp, im going to go ls turbo instead.
Old Aug 23, 2004 | 07:26 AM
showtymers619's Avatar
* B A N N E D *
Default Re: (blackeg)
you cant go wrong being gsr turbo in a hatch LOL might cost more but better in the long run...if money is the problem, then stay sngle cam.. blow them up all you want they are cheap to replace, i woul djust get a decent turbo kit, and start the motor blowup LOL
Old Aug 23, 2004 | 08:33 AM
DelSlow93's Avatar
Default Re: (ShowTymers619)
I was just wondering is there anyone that has boosted a d16z6? And if so what kind of power did you get?
Jon V's Avatar
C5 turbo
Old Aug 23, 2004 | 08:48 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (Jon V)
When you start a sentence with "wuts", instead of "what's" - it says a lot about the person looking to turbo their car.
Read Honda-Tech for about a year before you order any parts.
Old Aug 23, 2004 | 08:53 AM
kaoss_11's Avatar
B A N N E D
ls turbo
Old Aug 23, 2004 | 09:15 AM
jman30513's Avatar
go to http://www.d-series.org and do a search on member "beerbongkicksass"
made 216whp on first dyno run with no tuning
had over 85k on the stock motor and has been running it damn hard for the past 6 months
done
jman
Old Aug 23, 2004 | 09:16 AM
jman30513's Avatar
ok for you if youre lazy like me
http://www.d-series.org/forums...=4463
there
pretty pics too!
jman
