HELP! ? Crower rods
Old Aug 20, 2004 | 11:40 PM
TURBO4drTypeR's Avatar
Default HELP! ? Crower rods
Sorry to ask but its been awhile since i've touched a built motor...I'm in the process of assembling my setup and I would like to know "What are the torque specs on the crower billet rods for B18C?"
Thanks to anyone who answers my question
Old Aug 21, 2004 | 11:15 AM
Someone HELP!!! I forgot what the torque specs are...
anyone?
Old Aug 21, 2004 | 12:14 PM
beepy's Avatar
Default Re: (TURBO4drTypeR)
I am only finding two part numbers for the Crower Rod, ARP rod bolts:
3/8 x 1.6 45 ft-lbs
5/16 x 1.5 25 ft-lbs
I don't know which the B18C rods have.
Old Aug 21, 2004 | 01:09 PM
Default Re: (beepy)
THanks alot for that info!
I have the Crower bolts H2166A...dont know if it's the same specs as the ARPs
Anyone else? Thanks for lookin
Old Aug 21, 2004 | 01:33 PM
earl's Avatar
Measure your bolt diameter. If it is about 3/8" AND you can use a 7/16" 12 point socket on the head, it will be the 45lb torque bolt. That is probably the bolt you have unless you got the Crower Econos.
Old Aug 21, 2004 | 01:36 PM
1bad-eg's Avatar
Default Re: HELP! ? Crower rods (TURBO4drTypeR)
45 ft. lbs. I have crower's in my b18c block
Old Aug 21, 2004 | 02:18 PM
Thank you Earl and 1bad-eg!!! That is all the info I need... It's nice that you guys spared a minute of your time to type up some simple answers to my question!
If anyone else is reading this far please DO NOT post because I've got my answer!!!! LET MY THREAD DIE OR LOCK
Thank you
H22AJSPEC
Nov 6, 2010 09:03 PM
sscivicsi
Jun 29, 2008 05:43 PM
G_Man604
Apr 28, 2004 02:14 PM
niedejb
Dec 1, 2002 02:52 PM
BlwnBlue
Jan 22, 2002 04:31 PM
