which turbo to use?
Old Aug 21, 2004 | 10:50 PM
90 integra's Avatar
Default which turbo to use?
i have a 92 integra and im going to rev to 8k-8.5k and im looking to get around 350-400 whp but dont know what kind of turbo to use. i have a garrett airearched .60 comp and 1.32 tubine. i think i wont be able to spool this thing so i was whanting to buy another turbo. let me know asap.thanx
Old Aug 21, 2004 | 11:34 PM
PhantomSTi's Avatar
Default Re: which turbo to use? (90 integra)
What engine?
Old Aug 22, 2004 | 04:14 PM
90 integra's Avatar
its a b18a1. and its going to be built so it will hold the 350-400whp.
Old Aug 22, 2004 | 06:43 PM
ludetech
Guest
Posts: n/a
if your looking to just make 350-400whp that no problem. where are you looking to get power by. If you dont mind waiting a bit I would recommend the sc-61. if you want instant get the sc-34. I like a larger turbo tho because it will make more power at the same psi. and the less boost you run the colder your setup will run.
Old Aug 22, 2004 | 09:03 PM
90 integra's Avatar
thanx but im looking to get the least amount of lag i can becuase i dont like slow take offs but i dont tend to get anymore power then 400 whp untill i get me another car.also dont whant my car overheating becuase its my daily driver so let me know what turbo to use.thanx
Old Aug 22, 2004 | 10:26 PM
civtegra_hybrid's Avatar
Default Re: (90 integra)
try what you got and then upgrade.
Old Aug 22, 2004 | 10:42 PM
90 integra's Avatar
well this guy on here (stoopid)said its to big and my motor wont spool it.
Old Aug 23, 2004 | 03:23 AM
Syner-G-Racing LLC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90 integra &raquo;</TD></TR><TR><TD CLASS="quote">well this guy on here (stoopid)said its to big and my motor wont spool it.</TD></TR></TABLE>
apparently stoopid knows his shnit because hasport has refered him to me several times. unfortunately he was unable to help do to the situation. but if he says its to big it probaly is.
you have to remember there needs to be enough exhaust pressure plus the friction from the compressor side. I may spool up, but Im sure there will be lots of lag.
Old Aug 23, 2004 | 05:25 AM
adseguy's Avatar
yeah the 1.32 turbine is not going to work out for you. I have seen people with the .85 turbine side and they hate it becuase of the lag. When do you want to see full boost? The lower that number the harder it will be to see your 350-400WHP. With that in mind anything larger then a t3 60 trim should be able to put down the 350WHP with relative ease.
Old Aug 23, 2004 | 06:00 PM
90 integra's Avatar
well i need a common turbo like a t3 t4 t25 t70 t60 or something like that.like i said i whant a quick response so keep posting info.thanx
Old Aug 23, 2004 | 06:09 PM
Bailhatch's Avatar
I would just get a basic t3/t04e garrett hybrid. stage 3 turbine wheel with a .48 a/r and a 50 trim compressor .60 a/r. I just put this same turbo on a GSR and it spools up very fast but has some very nasty top end even at only 10psi.
Old Aug 23, 2004 | 07:58 PM
90 integra's Avatar
the mani i have is a 4 bolt so i need a turbo with a 4 bolt.
Old Aug 23, 2004 | 10:17 PM
90 integra's Avatar
what yall think about this one. its a t3 with a .63 a/r on the turbine and .60a/r on the compr.
Old Aug 24, 2004 | 05:37 AM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90 integra &raquo;</TD></TR><TR><TD CLASS="quote">what yall think about this one. its a t3 with a .63 a/r on the turbine and .60a/r on the compr.</TD></TR></TABLE>
Well you didn't tell us what size wheels, which is far more important than the A/Rs. It's like if someone asks what kind of car you drive and you tell them "it's red". There are like 4 turbine wheels and about 7 compressor wheels to pick for a straight t3.
But either way if you are reving to 8 and want over 350 a T3 won't cut it.
Old Aug 24, 2004 | 06:34 AM
-Trinitron-'s Avatar
on an LS you want a .48 turbine. If you want good power go with a .60 compressor.
007EG
Jan 27, 2008 07:21 PM
wicked2night
Dec 10, 2006 07:10 AM
driveahonda
Nov 17, 2006 07:17 AM
Schister66
Dec 10, 2005 09:26 AM
