Some last minute questions.....
I have a 99 LX, and wanted to install my Y8 IM and turbo this weekend, but looks like I need a little more help. I have a Y7, gonna put in a 14b. Let me start with the questions.
1) I want to use a Y8 IM. Originally I was told that I'd have to swap the Y8 TB with the Y7 TB. However after some reading, I read that if I use a OBD1 P06 ECU (Im gonna use Uberdata for fuel management), that I would need a 2 wire IAC. Thus I could keep the Y8 TB? Do I need to move that one pin on the ECU? I am using a OBD2-OBD1 conversion harness, where is this pin?
2) When running a OBD1 ECU, does it matter which O2 I use? Do I have to use the primary O2 from the exhaust manifold? I have a test pipe and I dont think the primary O2 would reach. Would I need to extend it,
or could I just use the O2 that was located on the cat?
3)When doing the coolant lines for the turbo, shoud I "T" both ends? I remember reading some erratic idle problems if I connected the TB coolant line directly to the turbo.
Re: Some last minute questions..... (DSC)
Can answer two of your questions I think, you will be fine cutting off the TB's coolant supply.
The primary 02 sensor is the one installed in your mani use that.
Re: Some last minute questions..... (turbozxi)
Cool bump for more answers. Also anyone one else using Virens CPR injectors? I have OBDI clips but they dont fit. I think I need to cut a line down the clip to make them fit? Thx.
u need to use the primary o2 sensor and yes most likely u will need to extend the wires. as far as coolant to the turbo is concerned... u lost me. You need an oil feed into the turbo and an oil return out of the turbo but i dont know what u mean by coolant to the turbo
Re: Some last minute questions..... (turbod16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 »</TD></TR><TR><TD CLASS="quote">you can use the coolant line off the TB.
about the o2 sensor, u can use any. </TD></TR></TABLE>
