machine shop help. ls rods on d series
Old Aug 22, 2004 | 12:26 PM
menkio's Avatar
Default machine shop help. ls rods on d series
anyone know what needs to be done, I'm dropping of my block monday, hone, polish jurnels, maganux, clean and machine my rods for my virita pistons. I'm wondering that exactly needs to be done, the piston end wider, the crank end smaller, aka bigger bearing?
added a picture, always gets help.. lol
Modified by DewMota at 11:56 PM 8/22/2004
Old Aug 22, 2004 | 02:55 PM
menkio's Avatar
Default Re: machine shop help. ls rods on d series (DewMota)
ttt
Old Aug 22, 2004 | 04:51 PM
menkio's Avatar
75 views... ttt
Old Aug 23, 2004 | 03:24 AM
menkio's Avatar
... ttt.. come on guys.. someone has to have done this
Old Aug 23, 2004 | 05:39 AM
mekkis's Avatar
Kerry Novak @ Crower can supply small end bushings so you can fit 19mm D-pistons to 21mm LS rods, $10 per bushing. You have to specify exact size desired; you play engineer. This setup requires using a floating wristpin + spiralocs... cough up $11/piston to have Arias modify them for spiralocs.
After all that hassle, LS rod is still not as beefy as the direct drop in 86-87 PG7 aka D16A1 rod. Gay!
Old Aug 23, 2004 | 05:41 AM
turbo sol's Avatar
do you have access to a machine shop yourself?
if not just get eagles. notching a block is easier then machining a rod.
BUT if you do it:
the large end that goes on the crank needs to be thinned down to fit between the d16 counter weights.
the small ends needs to be rebushed to accept the 19mm (i think that is the D16 size) wrist pin.
after you rebush you will need to use a floating wrist pin style piston, either aftermarket or modify your stock ones. (i suggest aftermarket)
here is what it sould look like when you are done:
Old Aug 23, 2004 | 07:42 AM
mekkis's Avatar
Default Re: machine shop help. ls rods on d series (turbo sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">if not just get eagles. notching a block is easier then machining a rod.</TD></TR></TABLE>
You haven't had to notch D-blocks for Eagles in a couple years, they revised the design.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">the large end that goes on the crank needs to be thinned down to fit between the d16 counter weights. </TD></TR></TABLE>
Yep, forgot that part.
Old Aug 23, 2004 | 08:21 AM
earl's Avatar
Default Re: machine shop help. ls rods on d series (mekkis)
spend the $ on eagles rather than do this...they will be 10 times stronger
Old Aug 23, 2004 | 08:30 AM
mos's Avatar
mos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mekkis &raquo;</TD></TR><TR><TD CLASS="quote">After all that hassle, LS rod is still not as beefy as the direct drop in 86-87 PG7 aka D16A1 rod. Gay!</TD></TR></TABLE>
I've always thought the d16a1 rods were just as weak as the rest of the d series rods...
Old Aug 23, 2004 | 08:46 AM
turbo sol's Avatar
Default Re: machine shop help. ls rods on d series (mos)
d16 rods probly are these are b18a/b rods we are talkign about.
I agree if i did it again i woudl go eagle.
Old Aug 23, 2004 | 09:18 AM
mekkis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">
I've always thought the d16a1 rods were just as weak as the rest of the d series rods...</TD></TR></TABLE>
The 88-89 are exactly the same as the "rest" of the D16 rods.
Stolen from egmike:
Those are 86-87's vs a set of D16Z6 rods... no pictoral comparo of LS vs early D16A1, but they are <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmike &raquo;</TD></TR><TR><TD CLASS="quote">~3.5mm thicker than LS rods (LS rods are the same thickness as d16z6) and about 2 mm narrower than LS.</TD></TR></TABLE>
That's "close enough for rocket science" for me.
IMO, great for D-series NA duty, good for super budget boosted build, but earl's right - you can afford to sling LS rods into a D-series you can afford Eagles that are five times as strong.
Old Aug 23, 2004 | 09:34 AM
menkio's Avatar
i talked it over with my machine guy and he says floating pin design is if if.. the reilbultiy factor goes down a bit, and taking material off the rods, not the best case.. he suggested eagles... so im going eagles, with virita pistons now.
Old Aug 23, 2004 | 09:35 AM
menkio's Avatar
anyone know the thermal coating stuff, where i can get it, etc ?, for the piston top, head, and skirts
Old Aug 23, 2004 | 01:35 PM
14bcoupe's Avatar
good choice on going with eagle rods
Old Aug 23, 2004 | 05:04 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">anyone know the thermal coating stuff, where i can get it, etc ?, for the piston top, head, and skirts</TD></TR></TABLE>don't bother
Old Aug 23, 2004 | 05:24 PM
mekkis's Avatar
Default Re: machine shop help. ls rods on d series (earl)
But... Earl... what about Akari Motorsport's phenominal line of ceramic coatings???
&lt;insert evil snicker&gt;
Old Aug 24, 2004 | 12:05 AM
menkio's Avatar
whats wrong with coatings... they have been proven to work....
Old Aug 25, 2004 | 05:44 AM
turbo sol's Avatar
as far as the 86-87 rods. They are bigger than the z6 rods, BUT the metaluligy (metal composition) of thet ealier rods basicallly equates to the same strength.
the LS rods are bigger than d16z rods (and have better composition than the ealier rods). look at my picture and decide what you would want.
but like I said go eagle.
**i could fit my z6 rods inside of the LS rods
Old Dec 22, 2008 | 12:30 PM
pettyboy69's Avatar
ya good choice go with vitara's and eagles i wouldnt worry about coating them they worked fine for me without it no problems at all with my vitara build and i drove it in foot deap snow all winter
Old Dec 22, 2008 | 12:49 PM
Golden Eagle's Avatar
why are you replying to a post from 2004 lol
Old Dec 22, 2008 | 10:21 PM
blinx9900's Avatar
damn i was so confused reading this thread and then bam i see this! pettyboy69 you are an ***!
Old Dec 22, 2008 | 10:35 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
lol wtf
Old Dec 23, 2008 | 03:38 AM
SD_Lurker's Avatar
HT White Ops
This is one of many he has resurrected over the past few days.
Old Dec 23, 2008 | 07:32 AM
HiProfile's Avatar
The problem is the damned search engine. It used to sort by date, but now guesses it's relevance and only shows ~5 threads per page. So your most relevant thread is several years old.
I thought we wanted the search engine to work BETTER???!
93preludes
Nov 23, 2005 06:17 PM
mr. vang
Oct 27, 2004 05:26 PM
lsvtec101
15
Dec 1, 2003 08:34 AM
ViperRedCRX
Dec 17, 2002 09:45 AM
00civicvtec
Jul 31, 2002 10:12 AM
