help SC61 will not spin at idle
Old Aug 22, 2004 | 06:30 PM
TURBODC4TEG's Avatar
Default help SC61 will not spin at idle
well, turbo will not spin at idle u can hit the gas and it will spin please help
Old Aug 22, 2004 | 06:38 PM
Default Re: help SC61 will not spin at idle (TURBODC4TEG)
up
Old Aug 22, 2004 | 06:42 PM
Boostage's Avatar
its a big turbo and its non ball bearing. it might not spin at idle on a 1.x litre motor but you are getting boost when driving right?
Old Aug 22, 2004 | 06:47 PM
Default Re: help SC61 will not spin at idle (Boostage)
yes
my motor is a 1.8 stock ls
does anyone know if there ls spins the sc61
maybe the compression might have something to do with it?
Old Aug 22, 2004 | 06:49 PM
SEFIxCivic's Avatar
if it doesnt spin thats not normal
Old Aug 22, 2004 | 07:00 PM
IMPORTant Si's Avatar
Default Re: help SC61 will not spin at idle (SEFIxCivic)
I had to do about 2 dyno pulls on my new SC61 before it would spin at idle. It sounds like it just needs to br broken in
Old Aug 22, 2004 | 07:03 PM
Default Re: help SC61 will not spin at idle (IMPORTant Si)
what do you think i need to do drive it around or what?
if i stick my finger in the compressor side i can free spin it
Old Aug 22, 2004 | 07:10 PM
Jared's Avatar
thats perfectly normal on an engine with low exhaust velocity at idle. do a search, this has been covered multiple times.
Old Aug 22, 2004 | 07:11 PM
DD_JonnyLee's Avatar
ive had 2 sc61's. sometimes they would spin, sometimes they wouldnt.i thought it was weird to , but they still made boost .so i didnt care.
-jonny
Old Aug 22, 2004 | 07:12 PM
Default Re: help SC61 will not spin at idle (Raped-Ape)
just worried because this is the 3rd one i got from precision
Old Aug 22, 2004 | 07:20 PM
Default Re: help SC61 will not spin at idle (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">thats perfectly normal on an engine with low exhaust velocity at idle. do a search, this has been covered multiple times.</TD></TR></TABLE>
i have searched can't find anything, post the link if you go it
oh by the way if you start the car at cold idle the wheel will spin and if you let the car warm up a bit, the wheel then quits spinning
plz help guys
Old Aug 22, 2004 | 07:31 PM
turbo*s2k's Avatar
it's nothing to worry about!
Old Aug 22, 2004 | 07:41 PM
Bailhatch's Avatar
Default Re: help SC61 will not spin at idle (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBODC4TEG &raquo;</TD></TR><TR><TD CLASS="quote">
plz help guys </TD></TR></TABLE>
Are you kidding?
I T
I S
N O R M A L.
There is no problem
Pretty much all turbos I have bothered to look at while running do this. I have a little t3 that doesn't always spin at idle and that thing only has a standard wheel and .63 a/r housing.
Old Aug 22, 2004 | 07:45 PM
Default Re: help SC61 will not spin at idle (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
Are you kidding?
I T
I S
N O R M A L.
There is no problem
Pretty much all turbos I have bothered to look at while running do this. I have a little t3 that doesn't always spin at idle and that thing only has a standard wheel and .63 a/r housing. </TD></TR></TABLE>
thanks anyone else, last time before my turbo messed up i only made 272 and 260 torque at 15psi
so something wasn't right with the turbo last time
is there any troubleshooting i can do to make sure i'm just very nervous about it
Old Aug 22, 2004 | 07:53 PM
SEFIxCivic's Avatar
the turbos i've owned spun at idle. i have a pt67 t4 on a 1.8 gsr. exhaust pulses are pretty strong and should have no problem pushing the turbo even at idle. i mean i can push the turbo with the slightest touch of my pinky finger and it will spin.
Old Aug 22, 2004 | 08:29 PM
up
Arturbo's Avatar
Better than steak
25 Year Member
After you sent me an IM I was thinking to myself, "it doenst spin". You should be good to go.
art
Old Aug 22, 2004 | 09:12 PM
Default Re: help SC61 will not spin at idle (Arturbo)
up
Old Aug 22, 2004 | 10:33 PM
civtegra_hybrid's Avatar
lol that's normally for a non ball bearing turbo to do that, my firend just bought a brand new T70 turbo, and put it on his fully fully built gsr and that **** still don't spin. but when he hits the gas pedel a tadd. that's ***** dirty. lol don't worry about it. if you want it to spin at 800rpms then go buy a gt sers. turbo, that runs about 1500. and then that **** will spin.
Old Aug 22, 2004 | 10:39 PM
93LSivic's Avatar
Default Re: help SC61 will not spin at idle (civtegra_hybrid)
totally normal. I have a 1.9L gsr and a sc61 with stage 5 wheel, it doesnt spin at idle.
Also people. There is no such thing as a break-in for turbo's. Unless its the HKS (i think its hks) that has a coating on the inside of the conpressor housing and the wheel will actually shave some of the material off to create a tight clearance.
Old Aug 22, 2004 | 10:45 PM
da ponch is back III's Avatar
Old Aug 23, 2004 | 12:04 AM
Default Re: (da ponch is back III)
anyone plz
Old Aug 23, 2004 | 01:43 AM
Cyber ITR's Avatar
Default Re: (TURBODC4TEG)
LOL
these people already told you , that IT IS NORMAL , what else do you want ??
Old Aug 23, 2004 | 05:43 AM
Code Blue's Avatar
Default Re: (Day Walker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker &raquo;</TD></TR><TR><TD CLASS="quote">LOL
these people already told you , that IT IS NORMAL , what else do you want ?? </TD></TR></TABLE>
i know right, you would think after Arturbo chimed in this guy would get the hint.
it is normal for some turbo's not to spin at idle. have you even driven the car to see if it hits boost?
Old Aug 23, 2004 | 01:50 PM
Default Re: (Code Blue)
up
