help... 'sheared' turbo manifold... how to remove?
Old Aug 22, 2004 | 10:56 AM
cornhusker's Avatar
Default help... 'sheared' turbo manifold nut... how to remove?
i am pulling off the old drag manifold and upgrading to a tubular manifold but i ran into a roadblock. i "sheared" (if that is the right terminology) nut off of one of the manifold studs. any suggestions on what to do?
i sprayed it down with wd40, let it sit for 30 minutes. all the other nuts came off with a little effort, but when i got to this one, the wrench wouldnt budge, and when it did, it spun around the nut and smoothed the corners/edges.
please lemme know, thanks in advance.
Modified by cornhusker at 2:14 PM 8/22/2004
Old Aug 22, 2004 | 11:05 AM
cornhusker's Avatar
Default Re: help... 'sheared' turbo manifold... how to remove? (cornhusker)
dunno if it helps, but this is the nut that is sheared, all the rest are already loosened.
Old Aug 22, 2004 | 11:16 AM
SuperTeg95's Avatar
hammer on a smaller 12pt socket and then hit it with an impact or air ratchet. Otherwise you may have to cut it off and put a new stud in its place. Good luck
Old Aug 22, 2004 | 11:21 AM
cornhusker's Avatar
Default Re: help... 'sheared' turbo manifold... how to remove? (SuperTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">hammer on a smaller 12pt socket and then hit it with an impact or air ratchet.</TD></TR></TABLE>
i dont have any air tools. any other ideas? thanks.
Old Aug 22, 2004 | 11:29 AM
Boosted2K's Avatar
you could always use the dremel, just be careful not to screw up the threads
I'd cut almost all the way through the use a chisel or something to split it
Old Aug 22, 2004 | 11:43 AM
ichibanjap's Avatar
Default Re: (Boosted2K)
Seeing as how the nut is already done, try some vise grips.
Old Aug 22, 2004 | 11:58 AM
toolowsol's Avatar
Default Re: (ichibanjap)
vice grips would remove that no problem.
Old Aug 22, 2004 | 12:37 PM
b20boost's Avatar
Default Re: (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">vice grips would remove that no problem.</TD></TR></TABLE>
thats what i did
Old Aug 22, 2004 | 01:42 PM
Street Ghost's Avatar
Default Re: (b20boost)
I say ViseGrips as well.
Old Aug 22, 2004 | 01:55 PM
cornhusker's Avatar
Default Re: (JDM Ninja)
i am at a friends house right now (i had to get away, i was getting so pissed)
anyways, thanks for the advice guys, i will give that a try when i get back home in a couple hours, hopefully it works out, i'll let you know how it goes.
Old Aug 22, 2004 | 01:59 PM
B18OnTop's Avatar
Default Re: help... 'sheared' turbo manifold nut... how to remove? (cornhusker)
A good investment is a set of craftsman stripped bolt taker outers. That’s not the exact name but it something along those lines. A little expensive but well worth the price.
-Aaron
Old Aug 22, 2004 | 02:05 PM
tvrsir's Avatar
Default Re: help... 'sheared' turbo manifold nut... how to remove? (B18OnTop)
that **** is too big to put over the area he's trying to get it in to. vise grip is gonna be your best friend there.
Old Aug 22, 2004 | 04:52 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: help... 'sheared' turbo manifold nut... how to remove? (tvrsir)
vice grips will work but if you end up worsening the situation, hammer on a 12mm socket and go from there. If that doesn't work, you can try a craftsman tool specifically designed to do what you're trying to do. If you don't wanna buy that, go to a hardware store and get a screw/bolt extractor kit and you can extract the entire stud (you'll have to buy a new one once you have the entire stud out).
I'd say the best bet is with hammering on a socket. PB blaster would help a lot too, it's better than wd40. You can buy it at walmart.
Old Aug 22, 2004 | 05:15 PM
boosted_dc2's Avatar
Default Re: help... 'sheared' turbo manifold nut... how to remove? (PreIudeSI)
check this **** out!!!!
heat it up with a torch, get it red hot, then take a candle and melt it into the threads. keep pushing th candle into the threads, between the nut and stud.
then leave it for at least 10 minutes, if you dont leave it it wont work. after 10 minutes i bet you can unscrew it with a pair of damn needle nose. this trick was tought to me by a guy that works on boat motors, this trick works well on axle nuts, suspension nuts and any other shity nuts.
good luck
Landon
Old Aug 22, 2004 | 05:22 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: help... 'sheared' turbo manifold nut... how to remove? (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">check this **** out!!!!
good luck
Landon</TD></TR></TABLE>
wow, interesting ive never seen that i will try when the time comes...
Old Aug 22, 2004 | 05:25 PM
m R g S r's Avatar
Landon, That sounds awsome, but I think that he may have a bolt in there, not a stud...
Old Aug 31, 2004 | 04:45 PM
cornhusker's Avatar
almost forgot to post
the vise grips worked like a charm, now i just need to find another nut. anyone know what size it is? also, for future reference, how would one go about removing/replacine on of the manifold studs? thanks.
Old Aug 31, 2004 | 04:58 PM
igo4bmx's Avatar
sears craftmen has a stripped bolt remover which is ******* awesome
BrakeDanceJ
May 30, 2008 08:02 PM
numbnuts22715
Jan 16, 2007 03:23 AM
ah789454
Sep 28, 2005 10:43 AM
GDM Z28
Dec 28, 2003 09:04 PM
