posting d16z6 block?
Old Aug 24, 2004 | 12:48 AM
JdM_Eg_6's Avatar
Default posting d16z6 block?
is it a safe procedure to post you d16z6 block to help it withstand the 10-20 psi?
Old Aug 24, 2004 | 04:37 AM
Joseph Davis's Avatar
Default Re: posting d16z6 block? (JdM_Eg_6)
Posts don't help you withstand 10-20 psi, tuning does.
Seen a few "properly" installed posts, as per Widmer's specifications, lead to cylinder wall failure. Flat out, stock liners swell under boost, the post won't allow the liners to swell where they are screwed into it, the sleeve cracks at right angles to the post.
As far as 10-20 psi, if you have forged rods, why not? Depending on build and turbo, that places you 200-300 ish range, which the stock liners can withstand if tuned correctly. A friend was running 14 psi on stock D16Z6 for a few months, head gasket finally let go...
Old Aug 24, 2004 | 11:00 AM
JdM_Eg_6's Avatar
Default Re: posting d16z6 block? (J. Davis)
thanks for they reply.. im new to this so what do you mean by tuning? like taking it to the dyno and havin professionals tune it lmk thanks?
Old Aug 24, 2004 | 11:31 AM
-Trinitron-'s Avatar
yes, tuning is when the engine management is adjusted to best support the mods that have been added to the vehichle.
Old Aug 24, 2004 | 12:00 PM
JdM_Eg_6's Avatar
Default Re: posting d16z6 block? (-TRINiTRON-)
what all would i need to tune this motor properly to get 250hp at least out of it?
Old Aug 24, 2004 | 06:11 PM
JdM_Eg_6's Avatar
bump
Old Aug 24, 2004 | 06:13 PM
Gesundheit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Seen a few "properly" installed posts, as per Widmer's specifications, lead to cylinder wall failure. Flat out, stock liners swell under boost, the post won't allow the liners to swell where they are screwed into it, the sleeve cracks at right angles to the post.
And block guards cause hot spots...
As for th eposting: http://www.muller.net/sonny/crx/engine/posted.html
lilshady6796
Sep 5, 2009 08:13 AM
spooncivic1
Sep 25, 2005 04:59 PM
civictypr
Sep 12, 2004 06:28 AM
hondacivic4g
Feb 2, 2003 09:40 PM
td04civic
Mar 19, 2002 11:36 AM
