Radiotor fluid loss every 3 weeks
Old Aug 22, 2004 | 04:54 PM
Hondadrvr215's Avatar
Default Radiotor fluid loss every 3 weeks
Every 3 weeks apprx, the water temp gauge shoots up than I'd have to add coolant than it would be fine (about a cup and half worth).
Compression check shows good compression, no blown gasket, etc. Everthing would be fine for 3 weeks than it would start all over again.
Its a daily driver and I boost occasionally on the weekends.
Is coolant loss (evaporation, etc...?) normal for FI setups?
Old Aug 22, 2004 | 05:06 PM
Muckman's Avatar
Moderator in Chief
Default Re: Radiotor fluid loss every 3 weeks (Hondadrvr215)
Do you notice any puddles under your car after parked?
Old Aug 22, 2004 | 05:08 PM
Tushner's Avatar
Default Re: Radiotor fluid loss every 3 weeks (Muckman)
Bubbles at the radiator neck with cap off = BHG.
Old Aug 22, 2004 | 05:10 PM
D-Man's Avatar
sounds like the beginnings of a blown headgasket
Old Aug 22, 2004 | 05:30 PM
m R g S r's Avatar
Do you have a coolant overflow tank on it? If not that may be the problem. . .
Old Aug 22, 2004 | 06:34 PM
Default Re: Radiotor fluid loss every 3 weeks (m R g S r)
I have coolant overflow tank...
I boosted HARD after putting in coolant and levels were fine. Gonna check for bubbles tommorow.
So, uncap the top and look for bubbles while idling..? or rev it a little?
Old Aug 22, 2004 | 06:52 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Go pick up some ARP headstuds. You'll need 'em soon.
https://honda-tech.com/zerothread?id=967017
Old Aug 22, 2004 | 08:03 PM
IN VTEC's Avatar
Check the inside of the cabin on the footwells and floorboards.
Old Aug 22, 2004 | 10:23 PM
Tushner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondadrvr215 &raquo;</TD></TR><TR><TD CLASS="quote">I have coolant overflow tank...
So, uncap the top and look for bubbles while idling..? or rev it a little?</TD></TR></TABLE>
Depends on how blown the gasket is. Just take the cap off (engine cold) and let her run. You'll know pretty quick whether or not the thing is blown. Also look for particles of the head gasket on the radiator cap itself.
Old Aug 23, 2004 | 08:25 AM
Default Re: Radiotor fluid loss every 3 weeks (redteg_87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg_87 &raquo;</TD></TR><TR><TD CLASS="quote">
Depends on how blown the gasket is. Just take the cap off (engine cold) and let her run. You'll know pretty quick whether or not the thing is blown. Also look for particles of the head gasket on the radiator cap itself.</TD></TR></TABLE>
Yeah, I found particles of the HG in my radiator.
Old Aug 23, 2004 | 08:30 AM
SOHC_MShue's Avatar
is your overflow filling up to the top when it overheats? That is a sure sign that you blew the headgasket.
Old Aug 23, 2004 | 11:32 AM
Default Re: Radiotor fluid loss every 3 weeks (SOHC_MShue)
Strange thing is the overflow level is CONSTANT even after boosting 14 psi on pump, on the road for 20 minutes, everthing checks out, no leaks, checked for puddles...nothing, but 3 weeks later, gotta add a cup's worth of coolant...
I think it might be just evaporation of sum sort possibly...?
Old Aug 23, 2004 | 09:09 PM
ttt
mitchc05
12
Aug 19, 2007 04:15 PM
Rsqd
Nov 3, 2005 09:36 AM
mathews
Oct 4, 2005 02:45 PM
92integraVTECgsr
Aug 27, 2005 02:44 PM
Goldfingiz
Jul 25, 2003 06:20 PM
