Came back from the DYNO what do you guys think?
This is what i made at 20psi on the SC61
this was a conservitive tune AFR was kept to a 12.1 and the car ran on MotorSport 109- we did not tune the cam gears at all on this set up, i was having some crankcase vent. problems when i was at the dyno and later realized my catch can was setup wrong... oh well next time i am hoping to reach 400hp
Re: Came back from the DYNO what do you guys think? (EM1 MIKE)
Well on my invoice it says 08-06-2004 well that was early this month ... just been tied up with school and now i had the chance to post it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1 MIKE »</TD></TR><TR><TD CLASS="quote">The date says 06-08-2004 and you just came back from the dyno?
(Good dyno #'s btw, )</TD></TR></TABLE>
Its probably using that Euro style dating.
Moderator
Re: Came back from the DYNO what do you guys think? (Teg4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg4e »</TD></TR><TR><TD CLASS="quote">Isn't 320whp really low for your setup?</TD></TR></TABLE>
I tend to agree, especially with the higher compression and amount of boost being used with that application.. We've had easily 30 more wheel hp at only 12 psi.
Something for some reason doesn't seem right.
I'm gonna jump in and defend this guy.......I've had many cars on the same dyno he used. To put it simply, the dyno at vishnu reads quite a bit lower than any other dyno I've ever seen. If it had been a dynojet the numbers would have been alot closer to 360-375. I don't want to start the whole which dyno is more correct debate, but their dyno has always read about 15-19% lower than any other dynos in the area.
Moderator
Re: Came back from the DYNO what do you guys think? (enginetiks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enginetiks »</TD></TR><TR><TD CLASS="quote">I'm gonna jump in and defend this guy.......I've had many cars on the same dyno he used. To put it simply, the dyno at vishnu reads quite a bit lower than any other dyno I've ever seen. If it had been a dynojet the numbers would have been alot closer to 360-375. I don't want to start the whole which dyno is more correct debate, but their dyno has always read about 15-19% lower than any other dynos in the area. </TD></TR></TABLE>
That's very true, but even so, at 20PSI? There is definately something inefficient about that setup.
Re: Came back from the DYNO what do you guys think? (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">
That's very true, but even so, at 20PSI? There is definately something inefficient about that setup.</TD></TR></TABLE>
To which is why I asked what I did...
Re: Came back from the DYNO what do you guys think? (Bryson)
I was never saying that the car wqas making the power it should be. I just wanted to state a few facts about the dyno that was used. I'm just wondering why the graph stops at @7500 rpm?
running bewteen 20-22 degree timing
This dyno run was not attended for max power because we ran into some problems, the engine misfired when more timing was givin and durring another power run a big puff of smoke came out of the motor... the dipstick flewout of the motor becuase the catch can setup was wrong... the crank was getting pressurized at high rpm.... another problem was my tire was getting flat on the dyno ...
After a long day... plus he was having some trouble of his own some thing about the car red lining at 8800 and his dyno did not show that instead it was reading something else .... ???? i dont know what was going on.. ?
Turbo: specs .70/.68 SC61 T04S-E cover
Engine bore. stock 1.8L b18c1
Wheel? well i dont know exactly what wheel i am using on the compressor: its and SC61 (GT Wheel?)
Re: Came back from the DYNO what do you guys think? (TurboTegB18c)
the engine was stoping at 8750 but the graph showed something else ?? something with the gearing interpoluation (sp) of the dyno...
Re: Came back from the DYNO what do you guys think? (Jordo)
of the dyno dynamic dynos ive used, they read around 5% lower, 10% max. they are pretty sweet.
anyways, i dunno what kind of race gas you used, but i noticed you said the car misfired when u advanced the timing, probably detonation, did you try backing off the timing?
w/ only that kind of power, u could have used a lower octane, ie. 96-100 or so, even 93, but cali only has 91.
Well when i was dynoing the car it was connected from the brass nipple on the turbo to can and then from the can to the pvc outlet.. behind the block..
Re: Came back from the DYNO what do you guys think? (Mase)
the car stoped missing when the gap on the plugs was closed to a .024 thousands (bkr7e-11) well he told me to come in with a higher octane gas so i decided to chose VP motor sport 109...
Re: Came back from the DYNO what do you guys think? (TurboB18C1)
plus vishnu's dyno is notorious for reading low.
stock STi dyno 210-220 hp and on others dyno 250-260hp ie mustang dyno
stock WRX dyno 150ish or so on his dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18C1 »</TD></TR><TR><TD CLASS="quote">the dipstick flewout of the motor </TD></TR></TABLE>
Awesome. Anyone get that on video?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18C1 »</TD></TR><TR><TD CLASS="quote">the car stoped missing when the gap on the plugs was closed to a .024 thousands (bkr7e-11) </TD></TR></TABLE>
I would try some 8 heat range plugs.
