coolant problem (i hope its not the hg)
well after beating on my car some times, it over heats. I pull over and hit the rad cap pressure release (running a 79 civic rad) and the coolant bubbles out. after a week or so the coolant level drops in the radator like 2 inches. Am i boiling out coolant because my radiator is too small or its the hg? I got a cometic .046 and arps torqued to 75ft/lbs that only has 2k miles on it, so i find it hard to believe its shot already
what do you guys think, is it possible to boil out coolant due to a too small radator?
Re: coolant problem (Mad Chemist)
i doubt its your headgasket. you said your running a 79 civic radiator. do u mean 97? and also whats your setup. if ur using a stock radiator it is possible that your motoro would over heat with boostand cause it to boil. i have no definet answer sorry. bump
Re: coolant problem (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">i doubt its your headgasket. you said your running a 79 civic radiator. do u mean 97? and also whats your setup. if ur using a stock radiator it is possible that your motoro would over heat with boostand cause it to boil. i have no definet answer sorry. bump</TD></TR></TABLE>
no... i mean 79, its a smaller half rad that fits crx lovely
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">is your overflow tank overflowing or filling up all the way to the top?</TD></TR></TABLE>
it fills sometimes but goes down (maybe a small leak?)
See if you have ANY traces of oil in your coolant. If so then its your HG. If there's no oil then you might have a very small leak somewhere
Goodluck
Goodluck
Re: coolant problem (TURBO4drTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO4drTypeR »</TD></TR><TR><TD CLASS="quote">See if you have ANY traces of oil in your coolant. If so then its your HG. If there's no oil then you might have a very small leak somewhere
Goodluck</TD></TR></TABLE>
i dont see any oil in the water or water in the oil, both check out, so hte only place would be burning it, it has to be a small leak in the overfill, anyone knows where to get a generic polished looking overflow, small in diamter like the catch cans.
Maybe relplacing 17 year old honda plastic will solve my problem
DelSol-B18
27
06-27-2013 04:16 PM
