P91 ECU work for Uberdata?
Old Aug 21, 2004 | 08:19 AM
spike's Avatar
Default P91 ECU work for Uberdata?
I bought a OBD1 B18B swap and received a P91 ECU with it.. first off - is there anyway to check if the ECU is for Manual or Auto other than trying it?
Secondly - will this ECU work for Uberdata? And who has suggestions on who I should get to socket the ECU and add a USB for datalogging?
TIA!
Spike
Old Aug 21, 2004 | 11:32 AM
spike's Avatar
Default Re: P91 ECU work for Uberdata? (spike)
ttt
Old Aug 21, 2004 | 03:03 PM
spike's Avatar
one more time.
Old Aug 21, 2004 | 05:36 PM
b18cls1's Avatar
yes you can the p91 is a jdm 1.6 vtec sohc .
as for automatic open the ecu and look for three black parts with 5 legs on the upper left of the ecu with the plugs to the left...
you can convert a auto to manual.
Old Aug 21, 2004 | 08:01 PM
spike's Avatar
Default Re: P91 ECU work for Uberdata? (b18cls1)
will this ecu work on my b18b? This was included as part of the swap.
Old Aug 21, 2004 | 08:29 PM
Sonny's Avatar
What is the full part number on the side of the ECU?
Ie,
37820-PR4-A01
37820-PR4-A51
The USDM ECU's that end in "A5x" are auto ECU's. The ones that end in "A0x" are manual ECU's. I'm not sure if the same applies to the JDM ECU's.
Sonny
Old Aug 21, 2004 | 09:24 PM
b18cls1's Avatar
Default Re: P91 ECU work for Uberdata? (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Ie,
37820-PR4-A01
37820-PR4-A51
Sonny
he said it was a p91 ecu not a pr4 or p75 ls ecu and yes it will work it just wont read the vtec tables
and fyi what you have is the jdm equal of the us p28
Old Aug 22, 2004 | 08:34 AM
spike's Avatar
Excellent.. thanks!!
panaphobic
May 6, 2008 07:25 PM
panaphobic
May 6, 2008 11:48 AM
ek_will
May 4, 2003 07:24 PM
