How to install a Block Guard?
Old Aug 23, 2004 | 06:45 PM
AlienKrOZ's Avatar
Default How to install a Block Guard?
How do you install a BG proper? How much do machine shops charge for a install on a BG? What else do I have to install or do when putting in a BG?
Old Aug 23, 2004 | 07:04 PM
RyanEJ8's Avatar
Default Re: How to install a Block Guard? (AlienKrOZ)
Carefully tap in. Then hone the block. Easy as that.
Old Aug 23, 2004 | 07:07 PM
AlienKrOZ's Avatar
Default Re: How to install a Block Guard? (RyanCivic2000)
would i have to pull out the pistons, rods, cranks, etc out to hone the block
Old Aug 24, 2004 | 08:14 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">would i have to pull out the pistons, rods, cranks, etc out to hone the block</TD></TR></TABLE>
Yes, but it is not absolutely necessary to hone the block afterwards. Just extra precaution. To be honest, my block was honed before the block guard install.
Old Aug 24, 2004 | 08:50 AM
turbosol's Avatar
I installed a block guard in a b16 a long time ago and warped my cylinder out of round. I had to bore the motor .020 and get new pistons. I wouldn't recommend a BG personally, I had great luck without one on my next motor.
Old Aug 24, 2004 | 08:53 AM
-Trinitron-'s Avatar
Default Re: How to install a Block Guard? (turbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol &raquo;</TD></TR><TR><TD CLASS="quote">I installed a block guard in a b16 a long time ago and warped my cylinder out of round. I had to bore the motor .020 and get new pistons. I wouldn't recommend a BG personally, I had great luck without one on my next motor.</TD></TR></TABLE>
TRUE! If you just "tap it in" it will egg-shape the cylinder walls. If you are going to add a block guard, do it before all your machine work.
Old Aug 24, 2004 | 10:21 AM
RyanEJ8's Avatar
I would like to know who measured it and how much out-of-round the cylinder actually was. I don't see how it is possible that a little aluminum blockguard could warp the much larger cylinder sleeves that are partially made out of steel. If anything the blockguard would distort, not the sleeves.
Old Aug 24, 2004 | 10:50 AM
Squirtle's Avatar
My blockguard sat right in with no problems. Just waiting for intial start up.
Old Aug 24, 2004 | 01:33 PM
fullracegsr's Avatar
Default Re: (squirtle)
i had to beat mine in hard... once it passes a certain point when installing it's impossible to get out... i pounded it in and bored .020 over... no problems yet... i wouldnt insall it in a motor not being disassembled... but that's just me...
Old Aug 24, 2004 | 01:40 PM
RyanEJ8's Avatar
Default Re: (fullracegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullracegsr &raquo;</TD></TR><TR><TD CLASS="quote">i had to beat mine in hard... once it passes a certain point when installing it's impossible to get out... i pounded it in and bored .020 over... no problems yet... i wouldnt insall it in a motor not being disassembled... but that's just me...</TD></TR></TABLE>
Pounding on it wasn't exactly the best idea. Glad it worked out good though. Blockguards are good protection to help keep the cylinder walls from walking or shifting.
Old Aug 24, 2004 | 02:15 PM
AlienKrOZ's Avatar
Default Re: (RyanCivic2000)
when you guys did the drop in did you just pull the head out and drop it in? or did u hone the block out also? i want to just drop it right in with at a machine to have it pressed and weld it probably. i reallie dont want to disassemble the block and hone it.
Old Aug 24, 2004 | 03:07 PM
Squirtle's Avatar
When I installed mine the block was completely dissambled. I also would like to know if there's more people out there that went without honeing the block and experiences they had?
Old Aug 24, 2004 | 03:09 PM
Gesundheit's Avatar
why pay for a block guard, when you can post your cylinders for 10.00?
http://www.muller.net/sonny/crx/engine/posted.html
Old Aug 24, 2004 | 03:11 PM
USDM 4G VTEC's Avatar
the proper way to install a blockguard is
1- all parts needs to be perfectly clean
2- heat the block and block guard to working temperatures
3- press the block guard in with slight pressure...
4- once its snug, let it cool
5- once cool , its needs to be machined, and surfaced, so its as the block surface... means u are machining whatever didnt go into the block......
thats it...... normally its honed afterwards... and or work on whatever else u doing into the block
Old Aug 24, 2004 | 03:23 PM
Squirtle's Avatar
Posting is not a bad option, but does take more skill to align and drill in the proper areas. Sleeving is even better but not in everyones budget. Any more info on dropping block guard and honeing.
Old Aug 24, 2004 | 03:31 PM
AlienKrOZ's Avatar
Default Re: (USDM 4G VTEC)
it would be reallie be if i just pull the head out and drop the BG in and pull the head back on and call it a day right?
Old Aug 24, 2004 | 04:56 PM
Default Re: (AlienKrOZ)
diffently sounds easier than it is done... i thought the same thing... i had to do quite a bit of filing and even when i thought it was good i got it 1/2 into the sleeve and needed to file it more... it wouldnt come back out so i opted to beat it in rather than get tapping srews and try to pull it out with a hoist... i thought i messed the block for sure but when the machine shop bored it everything was ok...
Old Aug 24, 2004 | 05:38 PM
B18 CYA's Avatar
well, the shop that installed my blockguard and pistons and rings and rods did not hone my block after installing it .... now my piston rings are done since they haven't sealed properly. oh well i'm rebuilding over the winter for a way crazier setup
Old Aug 24, 2004 | 07:39 PM
hoya_10fintec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">it would be reallie be if i just pull the head out and drop the BG in and pull the head back on and call it a day right?</TD></TR></TABLE>
I don't know about other ppl but this is what I did..
I had to tap it in pretty hard..(GE BG &lt;--- not recomended) and that was after filing and trimming the BG for a long time.. and when I put it in, I couldn't get it back out so I put it in anyways and drilled the BG where it was really tight to weaken the BG... I know I did pretty stupid **** but it works!
I've put about 5000km so far and no problems as of yet.. we'll see how it goes..
Old Aug 24, 2004 | 09:31 PM
DRIVENRacing's Avatar
DONT do it yourself... let a cnc machine shop do it, it has to be pressed... the correct way of doing it if yer smart...
Old Aug 25, 2004 | 08:01 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">when you guys did the drop in did you just pull the head out and drop it in? or did u hone the block out also? i want to just drop it right in with at a machine to have it pressed and weld it probably. i reallie dont want to disassemble the block and hone it.</TD></TR></TABLE>
It is not necessary to weld it in. Just tap it in.
Old Jul 19, 2010 | 02:24 PM
d350l4710n's Avatar
What block guard did you get? Also, this post was a long time ago, have you since then ran the engine. If so, were there any problems?
I appreciate any feedback I can get.
Thanks
Old Jul 19, 2010 | 02:43 PM
welfarepc's Avatar
you just failed, sir.
Old Jul 19, 2010 | 03:07 PM
blackmugensivic's Avatar
^^lol
oh come on, it's only been 6 years
SilverWarrior
13
Mar 6, 2008 10:17 AM
all-mtr-teg
Aug 25, 2007 11:59 PM
lovey408
Apr 13, 2007 06:35 PM
dohdoh420
Feb 21, 2006 10:43 PM
yeegsr
13
Dec 27, 2004 05:05 AM
