Fuel Rail Necessary?
Old Aug 21, 2004 | 02:39 PM
hitvtecgetloud09's Avatar
Default Fuel Rail Necessary?
i just put on a custom turbo kit on my 99 si and i was wondering is it necessary to have injectors and a fuel rail. with stock ecu?
Old Aug 21, 2004 | 02:44 PM
95GSRTT
Guest
Posts: n/a
Default Re: Fuel Rail Necessary? (hitvtecgetloud09)
injectors yes, fuel rail no
Flr Power's Avatar
You don't need a fuel rail unless you start pushing around 1000+ hp. Get rid of the stock ECU and get yourself an AEM EMS or something similar with injectors matching your desired HP goal.
Old Aug 21, 2004 | 02:50 PM
Default Re: Fuel Rail Necessary? (coocoo32)
if i were to keep my ecu stock for the time being cuz im low on cash, would i need to change my injectors? btw this is a daily drive car so its not goin to be seeing much track time. or much boost in that matter.
Old Aug 21, 2004 | 03:26 PM
bumb.
Old Aug 21, 2004 | 04:11 PM
95GSRTT
Guest
Posts: n/a
if you dont have money for a any kind of fuel management, i wouldnt recommend running ANY kind of turbo. You will blow your **** faster than it took you to put it on. Fuel managment in the KEY to turboing a honda.
Old Aug 21, 2004 | 04:24 PM
Default Re: Fuel Rail Necessary? (95GSRTT)
i have a fmu on there i was askin about injectors.
Old Aug 21, 2004 | 04:29 PM
project dc2's Avatar
you dont need to upgrade the fuel rail
if your runnin the FMU, you better have an inline fuel pump, not an in-tank, but an upgraded inline, the intank cant keep up with the needed pressures of an FMU.
injectors and hondata./ aem EMS is the preferred route,
you cannot run upgraded injectors without a means of tuning them or trimming fuel such as fuel controller or hondata, ur car will just run super rich and not be able to idle. or drive properly.
Old Aug 21, 2004 | 07:37 PM
Default Re: Fuel Rail Necessary? (project dc2)
i have an intank walbro 255..isnt good enough?
Old Aug 21, 2004 | 08:47 PM
donkiman's Avatar
u do not want to put bigger injectors in without tuning. my recomendation would be (because i know your dieing to boost) put the turbo kit on and run stock injectors just keep the boost very very low. dont install the new injectors until you get a decent ems. hondata is a cheaper route than aem and uberdata is even cheaper
spoon95eg
Dec 23, 2005 01:56 PM
b17integra
Apr 13, 2005 10:28 PM
ITRSpeed
Feb 3, 2004 03:42 PM
dust1
Apr 29, 2002 06:34 PM
Type-ARR
Feb 28, 2002 01:41 AM
