problem with obd2 2000gsr with revhard A/C kit
the car will not start, it will start if i hold the pedal WOT but will not go above 1k rpms, i have checked for spark, it is running a inline pump and a FMU, seems that the engine is running rich, i have tried removing the FMU. put new plugs in. it still will not start and idle correctly. anyone help, thanks
Re: problem with obd2 2000gsr with revhard A/C kit (boostedcivichatchbacksi)
Try takingoff the map diffuser And see if it starts If so, then the checkvalveis backwards. GoodLuck!
i ♥ my honda
Global Mod
Global Mod
Re: problem with obd2 2000gsr with revhard A/C kit (revhardceo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhardceo »</TD></TR><TR><TD CLASS="quote">then the checkvalveis backwards. GoodLuck!</TD></TR></TABLE>
50$ says its backwards You should be able to blow through the TOP part
Hatch It
12-14-2004 07:40 PM
