adjust boost on my deltagate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">tighten it,screw it in...raises boost</TD></TR></TABLE>
Be very careful when adjusting the screw in... If you adjust it too much, it will keep the wastegate from opening and BOOM!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg »</TD></TR><TR><TD CLASS="quote">
Be very careful when adjusting the screw in... If you adjust it too much, it will keep the wastegate from opening and BOOM!</TD></TR></TABLE>
how will i know if I tightened it too much?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X »</TD></TR><TR><TD CLASS="quote">
how will i know if I tightened it too much?</TD></TR></TABLE>
Trial and error. tighten half a turn. then go for a drive. see where that put you to, and adjust from there
i've been looking for one around my area...for some reason no one has one...so I was just thinking about doing this for now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">Stop being cheap Nate! Ask mom and dad for money for a Boost controller!</TD></TR></TABLE>
wtf are you talking about? this isnt nate, i pay for all my ****...thanks
Is that all you need to increase boost beyond 4psi? I'm currently using a T3/T4 Garrett Hybrid setup with a Deltagate that seems to limit me to 4psi.. I can't seem to boost above that even having adjusted my Pop-Off Valve and having screwed in the Deltagate in a bit.. Someone has recommended a manual boost controller, but I wasn't quite sure if that would fix the problem.. my goal is 6psi.. any suggestions?
ok seriously, you made the decision to Turbo your car. At least do it the right way. Ghetto turbos always end bad, spend a couple bucks, get a boost controller. odds are there are a couple for sale in classifieds.
A cheap alernative might be http://boostvalve.com/
I have mine turned almost all the way in, im getting 12 psi. Its cheap, and will do until I can afford else.HTH
turbodan4
Mar 7, 2006 09:09 PM
376R
Nov 13, 2005 05:49 PM
WhiteSTi
Sep 26, 2003 10:30 AM
