Basemap + 3" Exhaust...Too lean?
Old 08-20-2004, 07:25 PM
DC_andrew's Avatar
Default Basemap + 3" Exhaust...Too lean?
Currently Im running a basemap on my setup (ls motor, uberdata, sc34) with a rough tune for 7 psi. As of now Im running the stock exhaust, but am about to switch to a full 3" setup.
What Im wondering, is whether or not switching to a full 3" exhaust setup will cause the car to run lean to the point where I need to get it tuned as soon as I get the exhaust on there? Will it be dangerous to run a 3" exhaust as opposed to my stock exhaust without getting it tuned right away?
Old 08-21-2004, 03:33 PM
DC_andrew's Avatar
No one knows?
Old 08-21-2004, 03:48 PM
Banned
Irishweird00's Avatar
Default Re: (DC_andrew)
put the 3" on and retard your timing 12 degrees... you'll be fine.
Old 08-21-2004, 03:54 PM
boosted_dc2's Avatar
Default Re: (Irishweird00)
generally anything you add that can change the curent setup you should retune. but if your boosting on a basemap, i guess you dont care about being tuned propperly anyway.
Landon
Old 08-21-2004, 04:08 PM
Banned
Default Re: (boosted_dc2)
good point... don't run to long on a basemap... if at all... bad news.
Old 08-21-2004, 04:31 PM
DC_andrew's Avatar
Well my tuner isnt available for a couple more weeks, so I was jw if I put the exhaust on now, if running it for those two weeks would do any serious damage. Ive only been running the basemap for a week though, but early september it will get tuned.
Old 08-21-2004, 07:57 PM
DC_andrew's Avatar
Oh, and just to clear things up a bit, Im not running on a "basemap" as it is normally refered to, I just meant its not tuned. Im running off a tuned map for a setup nearly identical to mine. Only difference is the intercooler I beleive.
Old 08-21-2004, 09:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_andrew &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and just to clear things up a bit, Im not running on a "basemap" as it is normally refered to, I just meant its not tuned. Im running off a tuned map for a setup nearly identical to mine. Only difference is the intercooler I beleive.</TD></TR></TABLE>
thats a basemap. if you boost on that youre crazy.
Landon
debogsr
08-12-2005 02:46 PM
m R g S r
08-01-2005 10:02 PM
Quick Reply: Basemap + 3" Exhaust...Too lean?
