turbo blown
Old Oct 6, 2006 | 08:10 PM
-mk2turbo-'s Avatar
Default turbo blown
how do you know when your turbo needs to be rebuilt, what does it do.
Old Oct 6, 2006 | 08:20 PM
EF9-CIVIC's Avatar
Default Re: turbo blown (-vdub-)
sometimes it whines really loud. or if the seals are bad it will smoke. or if it has alot of shaft play
Old Oct 6, 2006 | 08:29 PM
-mk2turbo-'s Avatar
Default Re: turbo blown (EF9-CIVIC)
it has alot of shaft play and its makes a clunking noise
Old Oct 6, 2006 | 08:34 PM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -vdub- &raquo;</TD></TR><TR><TD CLASS="quote"> it has alot of shaft play and its makes a clunking noise</TD></TR></TABLE>
yeah thats a good sign to get a new turbo
Old Oct 6, 2006 | 08:48 PM
EF9-CIVIC's Avatar
yea time for new turbo
Old Oct 7, 2006 | 09:37 AM
turbo_ls_69's Avatar
if theres smoke at idel or after u boost it hard
Old Oct 7, 2006 | 11:45 AM
-mk2turbo-'s Avatar
Default Re: (turbo_ls_69)
there's no smoke, just a loud clunking noise and a lot of shaft play. and the oil pressure light comes on but when you give it a little gas it goes off.
Old Oct 7, 2006 | 03:07 PM
program's Avatar
Default Re: (-vdub-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -vdub- &raquo;</TD></TR><TR><TD CLASS="quote"> and the oil pressure light comes on but when you give it a little gas it goes off. </TD></TR></TABLE>
Old Oct 7, 2006 | 03:18 PM
F20Cteg's Avatar
New turbo? or new motor?
Old Oct 7, 2006 | 08:41 PM
-mk2turbo-'s Avatar
Default Re: (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">New turbo? or new motor?</TD></TR></TABLE>
I hope not
Old Oct 7, 2006 | 08:51 PM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -vdub- &raquo;</TD></TR><TR><TD CLASS="quote"> there's no smoke, just a loud clunking noise and a lot of shaft play. and the oil pressure light comes on but when you give it a little gas it goes off. </TD></TR></TABLE>
yeah sounds like you are going to need a new turbo and rebuild the motor soon..... not a good sign if the oil light is coming on
Old Oct 7, 2006 | 08:58 PM
-mk2turbo-'s Avatar
Default Re: (BoostedEG6)
so the turbo wouldn't effect the oil pressure and make the light come on.
Old Oct 7, 2006 | 09:07 PM
Turbo-LS's Avatar
NOOOO !!!!
Dude when that light comes on that means there is no oil pressure. So if its flickering then youve got 5 psi or less oil pressure. Sounds liek your pump **** the bed or your low on oil or your motor is just shot. Either way if your hearing clunking then id say that motor is toast and the turbo too
Old Oct 7, 2006 | 09:15 PM
-mk2turbo-'s Avatar
Default Re: (Turbo-LS)
Old Oct 8, 2006 | 01:48 AM
program's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -vdub- &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
oil light on... ignition off ASAP!!!!
Old Oct 10, 2006 | 07:40 PM
-mk2turbo-'s Avatar
Default Re: (program)
ya it ended up being my motor
Old Oct 11, 2006 | 04:19 AM
TurbodTegSfaria's Avatar
clunking could be the oil pump eating itself up.. happened to me after a few high revs boosting.. i blew 3 oil pumps.. my turbos gotta be replaced/rebuilt i got tons of shaft play and it leaks oil on the inlet side, but i dont hear any clunks and still run it hard
D17alltheway
Honda Civic (2001 - 2005)
Mar 20, 2008 08:22 PM
IntegraMastaz
Nov 16, 2005 09:28 PM
crxzcracer
Jan 2, 2005 10:58 PM
fro
Oct 13, 2004 06:19 PM
SIK IN DA HED
Apr 4, 2004 09:42 PM
