Injectors
Old Oct 7, 2006 | 04:49 PM
cindysi's Avatar
Default Injectors
hey I have a stock 93 del sol and I am putting dc 440 injectors in it I have the hondata s300 but do I need to put a new feul rail in it or can I leave it with the stock one???
Old Oct 7, 2006 | 04:59 PM
NJIN BUILDR's Avatar
Default Re: Injectors (cindysi)
The stock fuel rail will be fine.But why are you putting 440's in a stock engine??
Old Oct 7, 2006 | 05:00 PM
Turbo95Hatch's Avatar
Default Re: Injectors (NJIN BUILDR)
obviously she wants to kill gas mileage for no performance increase. Maybe to shoot flames out the exhaust or nice black smoke?
Old Oct 7, 2006 | 05:18 PM
BoostedB16EJ's Avatar
Default Re: Injectors (Turbo95Hatch)
im confused? is this car turbo? if not then those injectors will drown that car. even on a small amount of boost 6-10 psi), 310s need tuned down.
Old Oct 7, 2006 | 05:43 PM
Default Re: Injectors (BoostedB16EJ)
I don't know why she wants to use 440', but with the Hondata it won't be any issue to control them.Mine runs fine with 750's.
Old Oct 7, 2006 | 06:05 PM
cindysi's Avatar
I wont drown the car out I have the hondata to adjust it. Thats not what I asked though.....
Do you need to change anything to have it work becaue we cant get the fuel rail to sit back into place with the bolts
Old Oct 7, 2006 | 06:27 PM
depending on the injector youre using ( namely RC or sometimes stock DSMs) that can be normal. typically those injectors dont seem to seat right on the rail. youre supposed to center them and just force it tight. it will seal that way. it does seem a bit hoaky, but it does work. if its an MSD injector, it will require some modification of the rail ( tapping out the injector ports) for them to fit.
if this doesnt seem to apply to you what kind of injectors are you using?
Brian_92GSR
Jan 10, 2012 10:43 AM
slow_ls
11
Jan 16, 2007 08:46 PM
96redgsr
Jul 21, 2004 09:46 PM
blykins
31
May 4, 2004 06:41 AM
Diego Boost
Feb 26, 2003 11:10 AM
