Cheack engine light....Boost+afc hack
Old Oct 5, 2006 | 09:16 PM
91jdmhatchback's Avatar
Default Cheack engine light....Boost+afc hack
Ok before anyone tells me to get real engine managment...First let me tell you this is my beater winter/daily car and i don't care enought to tune it on a dyno so i got the safc.
Well i got the car street tuned to like 11:1 AFR's in bost and i can't reember low throttle on my wideband. Thats the best me and my buddy chould get it to with the afc. Well with that said here is the set up not that is probally matters:
sls top mount mani.
sls IC pipes
Ebay fmic
custom 3" Dp Ends at the firewall
T3/T4 50 trim 60./63.(i know it is big)
dsm 450cc
safc 1
stock fuel pump
and the mighty D15 holdin at 205K miles
FORGOT TO AD: the car is a 93' civic dx
So my problem is when i'm on the interstate and i'm cruising like at a steady rpm/speed i will pop a CEL if i don't every 10 sec or so give it gas to change throttle position??? Whats up?
And also if i rip it in like 3rd gear it will throw a CEL???? whats up?
finally i got the codes it has been throwing :
1-o2 sensor #1
3-map sensor
43-fuel supply system
Modified by 91jdmhatchback at 3:24 PM 10/6/2006
Modified by 91jdmhatchback at 6:20 PM 10/8/2006
Old Oct 6, 2006 | 06:07 AM
Iceman05's Avatar
if you are OBD2, you will throw a code 13 (baro sensor) and there's nothing you can do about it.
Old Oct 6, 2006 | 12:25 PM
Default Re: (Iceman05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">make sure you entered the right number of cylinders and the correct sensor type and the "in and out" on the AFC setup menu.</TD></TR></TABLE>
Everything is entered correctly.... so i'm at a loss
Old Oct 6, 2006 | 03:21 PM
xenocron's Avatar
Default Re: (91jdmhatchback)
Might help if you told us what CEL it was actually throwing...
Old Oct 8, 2006 | 03:22 PM
Default Re: (xenocron)
Update on the codes
1- o2 sensor #1
3- map sensor
43- fuel supply system
i'm putting in a walbro this weekend so we will se hif that will take car of the fuel code
Old Oct 8, 2006 | 03:30 PM
Schister66's Avatar
Man U FTW
bump for pics of the codes....i dont believe you
do it...
Old Oct 8, 2006 | 03:35 PM
BobChestnut's Avatar
bump for answers....
paper headgasket FTW!
Old Oct 8, 2006 | 04:26 PM
92eg6's Avatar
Default Re: (BobChestnut)
i had the same problems but i had a reg. vafc. the o2 sensor must be just a bad 02 the map sensor is a bitch, i had the same prob even when i tried tricking it w/some prop valves so cant help u there, the fuel supply might be if u dont have a gas cap. i didnt, and then i got one and it went away. hope that helps a little.
Old Oct 8, 2006 | 06:06 PM
Default Re: (92eg6)
I have a gas cap... so thats not it. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problems but i had a reg. vafc. the o2 sensor must be just a bad 02 the map sensor is a bitch, i had the same prob even when i tried tricking it w/some prop valves so cant help u there, the fuel supply might be if u dont have a gas cap. i didnt, and then i got one and it went away. hope that helps a little.</TD></TR></TABLE>
Old Oct 8, 2006 | 06:12 PM
92eg6's Avatar
you had one the whole time? change ur fuel filter also
Old Oct 8, 2006 | 07:51 PM
Schister66's Avatar
Man U FTW
hey i have an idea....install your Walbro pump already...that would get rid of 2 of those codes
1. it would supply enough fuel so the O2 wouldn't see lean condition
2. Fuel supply wouldn't be a problem
Old Oct 8, 2006 | 08:30 PM
Default Re: (92eg6)
Again i have a gas cap and i changed my fuel filter when i put on the turbo kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">you had one the whole time? change ur fuel filter also</TD></TR></TABLE>
Old Oct 9, 2006 | 06:12 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">Update on the codes
1- o2 sensor #1
3- map sensor
i'm putting in a walbro this weekend so we will se hif that will take car of the fuel code</TD></TR></TABLE>
#1, Because you are running so rich or so lean, the ECU thinks your O2 sensor has gone bad, it may have...it may not have. Fix last of these three codes...
#3, could be something to do with how the AFC is Effing with your Map sensor signal...check over the wiring, go over the setup again and make sure everything is working nicely. Fix this code 1st of all your codes
#43, your fuel system code means that the long term fuel trims of the ECU has exceeded boundaries that were preprogrammed in. Could mean not enough fuel pressure, code mean your injectors are clogged, could be because of an O2 sensor, could be (most likely) that your MAP sensor code is causing this code and this code is causing your O2 code. Fix this second...
HTH
Old Oct 9, 2006 | 08:23 AM
92eg6's Avatar
i really think the vafc has to do w/the map sensor code, i had the same three codes w/my setup...bone stock ls w/revhard kit...stock injectors, stock ecu, w/255 fuel pump
Sic_DA_Nine
14
Nov 25, 2015 03:08 AM
professorman
Oct 15, 2013 09:55 PM
Takashi1978
15
Aug 20, 2005 08:13 PM
citrus3000psi
Nov 17, 2003 01:48 PM
Starscream
Sep 3, 2003 10:05 PM
