injector question
Old Oct 5, 2006 | 08:54 PM
spockeg's Avatar
Default injector question
i just got a set of pt 880cc injectors and one of my friends said that he thinks i need to run a risistor box with them. is that true or can i just throw them in and go. a nother qestion is, i'm running the s300 and i have read that the softwear has problem with biger injectors. is that still the case and do i have to dosomthing to correctt it?
thanks in advace, spock
Old Oct 6, 2006 | 10:41 AM
slodc2's Avatar
depends if your injectors are saturated or if they are peak and hold....saturated injectors u dont need a resistor box but peak and holds u do...i think most bigger injectors are peak and holds but u need to find out which of the 2 it is
Old Oct 6, 2006 | 11:10 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (slodc2)
i havent seen anything over 750 that arent p&h. easiest way to tell is if they are rc is the pn. sl are saturated, pl are peak and hold......if you still cant tell, ohm them. p&h net a 2-3ohm resistence, sats net a 12-13 ohm resistence.
Old Oct 6, 2006 | 11:50 AM
KeyserSoze's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">i havent seen anything over 750 that arent p&h. easiest way to tell is if they are rc is the pn. sl are saturated, pl are peak and hold......if you still cant tell, ohm them. p&h net a 2-3ohm resistence, sats net a 12-13 ohm resistence.</TD></TR></TABLE>
x2
Just put a fluke on em' and check the resistance. Resistance = impedance (well, not quite, but close enough in this case).
Old Oct 6, 2006 | 03:23 PM
xenocron's Avatar
Default Re: (KeyserSoze)
PT 880s are Low Imp
If your car doesnt have a resistor box, you need to add one or you will fry the drivers in your ECU
Old Oct 6, 2006 | 09:49 PM
spockeg's Avatar
Default Re: (xenocron)
coo that's just what i needed to know. i just wired up my resistor box and started it it ran perfect. thanks for the info, spock
LSej1
May 20, 2008 09:13 PM
nick91civicsi
Jul 28, 2006 05:27 AM
EJ8 GSR-T
17
Dec 16, 2005 12:54 PM
Sassafrass
Oct 9, 2004 09:58 PM
wrestler121
Oct 15, 2003 12:31 AM
