looking to make 300whp... which turbo to choose? t3/y4
Old 10-02-2006, 09:22 PM
flekz's Avatar
Default looking to make 300whp... which turbo to choose? t3/y4
i dont want a late spool... something fast and makes power... which would be best?
http://cgi.ebay.com/ebaymotors...QrdZ1
Old 10-03-2006, 06:55 AM
flekz's Avatar
Default Re: looking to make 300whp... which turbo to choose? t3/y4 (flekz)
bump
Old 10-03-2006, 07:24 AM
TTT
TTT's Avatar
NONE of them!! Stay away from XS Power/ SSAC turbos. They are junk! I have had people send them into me to be rebuilt and they are just a mess of different parts. You never know what you get.
Here is a smaller turbo that will reach your goals
Old 10-03-2006, 08:23 AM
T3k C's Avatar
You get what you pay for.
Old 10-03-2006, 08:29 AM
spooncivic1's Avatar
Default Re: looking to make 300whp... which turbo to choose? t3/y4 (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">NONE of them!! Stay away from XS Power/ SSAC turbos. They are junk! I have had people send them into me to be rebuilt and they are just a mess of different parts. You never know what you get.
Here is a smaller turbo that will reach your goals </TD></TR></TABLE>
i guess since you have used them you have experience, right?
before you go off tangent and start saying what the bandwagon has to say, let someone with experience talk first...there is an 8 page thread where people are using those turbos with aboslutely no problems. i know a couple of people personally that have been using them for a couple thousand miles...i'm personally going to be using one as well...just make sure you get an oil restrictor...oil pressure kills the seals in those turbos.
Old 10-03-2006, 09:48 AM
Man U FTW
Schister66's Avatar
shitty design and cheap parts kills those turbos
Old 10-03-2006, 09:55 AM
harlesjohn's Avatar
Default Re: (Schister66)
you can make 300 whp on a t3 just gotta have a good setup or a built motor
Old 10-03-2006, 11:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">shitty design and cheap parts kills those turbos</TD></TR></TABLE>
if you're worried about it, send it to blaast performance, they rebuild them for $250...so basically for under $500 you have a brand new garrett turbo
Old 10-03-2006, 12:18 PM
blackeg's Avatar
Default Re: (spooncivic1)
im gonna assume this is going on an ls motor. get a gt3071
since not everyone has cash to afford the ballin turbos...
i think a t3t4 50 trim will do it for you, but expect to run 15-18psi to get there
Old 10-03-2006, 12:51 PM
juda7's Avatar
I went with a Turbonetics 60-1 setup. Made good HP and the lag isn't bad. Also depends on the Tuner.
Jerry Built
Bubba Tuned
Thanks Tom @ Camp1320
Old 10-03-2006, 12:57 PM
85's Avatar
Default Re: looking to make 300whp... which turbo to choose? t3/y4 (juda7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juda7 &raquo;</TD></TR><TR><TD CLASS="quote">I went with a Turbonetics 60-1 setup. Made good HP and the lag isn't bad. Also depends on the Tuner.
Jerry Built
Bubba Tuned
Thanks Tom @ Camp1320 </TD></TR></TABLE>
I say get it! if all else fails, Its only $200 which would make a very cool paper weight/dining room table centerpiece! Im 1/2 tempted to buy one for that soul reason
Old 10-03-2006, 02:20 PM
flekz's Avatar
Default Re: looking to make 300whp... which turbo to choose? t3/y4 (hks85)
what about this? im not looking to spend buku money on a turbo... just a few bucks... lol cheapo supremo
Old 10-03-2006, 05:17 PM
blackeg's Avatar
yea that will work perfect for 300whp. its kinda close to the one i recommended.
dont buy a 60-1 to use on a stock ls, you will only have maybe 2000 rpms powerband, and wont be running enough boost to get the turbo into its efficiency range
Old 10-03-2006, 05:31 PM
Wideopentuning's Avatar
Default Re: looking to make 300whp... which turbo to choose? t3/y4 (blackeg)
A T3/T04E 50 trim with a .48 turbine housing and stage III wheel will do just fine and leave you some headroom.
Old 10-03-2006, 06:50 PM
85's Avatar
Default Re: looking to make 300whp... which turbo to choose? t3/y4 (Wideopentuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wideopentuning &raquo;</TD></TR><TR><TD CLASS="quote">A T3/T04E 50 trim with a .48 turbine housing and stage III wheel will do just fine and leave you some headroom.</TD></TR></TABLE>
you think that will work for a 2.5L? engine redlines @ 6.5K. 170hp 160lbs/ft stock
Old 10-03-2006, 08:44 PM
I would go with a .63 housing for sure with the larger engine. You could probably even utilize a stage V wheel.
Old 10-05-2006, 09:20 AM
for 300whp stage3 wheel and .63ar will be fine
Old 10-05-2006, 03:06 PM
-Trinitron-'s Avatar
If you are using a stock LS I would recommend a t3/04e .54/.63. I made 299 on 10lbs on a stock b16 with 85K miles on it. A B16 flows almost the exact same amount of air as an LS because of the RPM difference and VTEC. it spooled quick and drove daily well.
Old 10-05-2006, 06:01 PM
StckOnHvyChcks's Avatar
ebay brand turbos = poopy
irollerblade
Northeast (Sales)
01-09-2010 08:09 PM
dboz3403
07-26-2007 02:15 PM
HaitianEF9
01-08-2007 01:28 PM
fandango
03-21-2005 04:01 PM
Pullig
01-23-2005 05:21 AM
Quick Reply: looking to make 300whp... which turbo to choose? t3/y4
