B16 or LS-vtec boosted?
Old Oct 7, 2006 | 06:13 PM
swapped95's Avatar
Default B16 or LS-vtec boosted?
i have a B16A2 in my eg 4dr right now and i also have a B18A1 in my garage. should i build ls vtec for turbo or stick with the b16 motor? if so what pistons should i use in the ls? found wiesco pistons with eagle rods for $740ish...is that a good combo for ls vtec?
Old Oct 7, 2006 | 06:21 PM
NJIN BUILDR's Avatar
Default Re: B16 or LS-vtec boosted? (swapped95)
If you already have the b16 (which you do) I would use that.They are a tuff engine and make good power with the turbo.They have strong rods (and bolts),and a good stock intake manifold.
Old Oct 7, 2006 | 06:26 PM
swapped95's Avatar
i have an untouched B16 and an untouched ls. if i was to build either...should i build the ls vtec or the B16 bottom end...?
Old Oct 7, 2006 | 06:57 PM
Default Re: (swapped95)
The ls will make more power all else being equal,but the b16 can be a little cheaper to build.Lots of people have made good reliable power with stock b16s.If your going to build up one than the ls/vtec is the best choice
ser13
13
Sep 25, 2007 04:09 PM
1sikhatch
Sep 4, 2005 07:22 AM
jonathan13
13
Aug 23, 2005 12:04 PM
b16vtecsol
11
Nov 9, 2003 04:10 PM
roc
Nov 9, 2003 07:21 AM
