How can I tell which is the oil pressure sensor on a H22 engine?
As the title says, im looking to hook up a feed for a turbo and put an oil pressure gauge also. I dont want to get confused with the knock sensor or any others. I would just remove them and check for oil with a rag but the engine is sitting in a workshop stripped of all ancilaries. I knoew I should have taken a detailed picture before it went off
Any help would be great
Re: How can I tell which is the oil pressure sensor on a H22 engine? (djnikko)
You really can't miss the oil sending unit on the back of the block, especially since it's out of the car. just look for a circular sensor that is threaded into the block, you can tell it's for oil becuase you'll notice the oil journal running along the block below it. I tried to find a picture but i'm blind as hell and the search button don't like me. Also the oil sending unit is mostly centered and any auxillary sensors will be offset left or right of the oil sending unit.
If i'm not mistaken the knock sensor has 2 wires, and I don't know if it's threaded into the block.
Mike
Mike
Re: How can I tell which is the oil pressure sensor on a H22 engine? (Brain3208)
the oil light sensor is real close to the oil filter. it has a 90 degree black rubber boot on it with an 8mm bolt that holds the yellow wire with a ring terminal to it. the knock sensor is a one wire hookup that is just below the base of the head in the center.
vladd
06-26-2006 07:18 AM
