Which Gauges?
Old Oct 5, 2006 | 07:16 AM
Adamd's Avatar
Default Which Gauges?
Looking to get some gauges ready for turbo,
any ideas/advice on what brand to go for?
what do you lot use?
Get what you pay for sort of thing?
Cheers
Old Oct 5, 2006 | 07:20 AM
G2 Speed's Avatar
Default Re: Which Gauges? (Adamd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adamd &raquo;</TD></TR><TR><TD CLASS="quote">Looking to get some gauges ready for turbo,
Cheers </TD></TR></TABLE>
HT Search and Google Search
Old Oct 5, 2006 | 07:24 AM
Adamd's Avatar
Default Re: Which Gauges? (G2 Speed)
Old Oct 5, 2006 | 08:03 AM
nebulight's Avatar
I'm a big Fan of Stewart Warner gauges. They work great, and a decent price. You do get what you pay for, but I'm not a fan of spending hundreds of dollars on defi gauges though. I'm using a stock GSR motor with an SC61 and I bought a boost gauge and oil pressure gauge, and I also bought a PLX M-300 wideband but that's not really considered a gauge.
Old Oct 5, 2006 | 08:30 AM
boostin92hatch's Avatar
i like the new blox gauges.. look pretty sweet and dont cost an arm and a leg
Old Oct 5, 2006 | 08:34 AM
Mr HYDE's Avatar
Default Re: Which Gauges? (nebulight)
i use to have defi bf gauges but i sold them for these, i liek eth exact digital read out and warning lights. i know the defis are probably better but these are less cluster mess and more direct accurate
they light up red or green
heres evans old set up id liek to build one soon but have them lite red
Old Oct 5, 2006 | 08:50 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight &raquo;</TD></TR><TR><TD CLASS="quote">I'm a big Fan of Stewart Warner gauges.
+1 on the SW gauges. I really like mine.
Old Oct 5, 2006 | 09:03 AM
EJ1 wilcox's Avatar
Default Re: Which Gauges? (Buzzbomb)
I just use Autometer Sport Comp gauges. They are fairly inexpensive and work fine.
I can't justify spending hundreds and hundreds of dollars on gauges for a regular old street car.
Old Oct 5, 2006 | 09:48 AM
turbotime's Avatar
i just bought 3 of these
Old Oct 5, 2006 | 10:34 AM
Adamd's Avatar
Default Re: (turbotime)
cheers for the replys guys, ive been looking at the autometer cobalt series, what do you think?
Old Oct 5, 2006 | 10:39 AM
turbotime's Avatar
cobalt are cool,
i chose swoosh cause my oem gauges are white lettered- and so are the swoosh.
Cobalts are blue so they wouldnt match my schema. Good product tho!
annnddd, swoosh are defi knock-off [60mm] and record peak value, and have IGN self check
Old Oct 5, 2006 | 11:23 AM
dj9046's Avatar
buzz bomb where did you get that mount ?
Old Oct 5, 2006 | 12:27 PM
BoostedEG6's Avatar
Default Re: (dj9046)
I am running all Defi gauges.... here is a pic of mine..
Old Oct 5, 2006 | 12:31 PM
turbotime's Avatar
^ i see you have 1 gauge mounted using the "band" mount. Do you think there is room for 3 band-mounted 60mm gauges there in front of the vent thing [location you have yours]?
Old Oct 5, 2006 | 12:38 PM
BoostedEG6's Avatar
I have the Turbosmart e-boost mounted using the Band... I think it looks cleaner running them how I have them...... although I think there might be enough room for three of them though where you are asking
I dont have any heat/AC or radio in my car so I am using a custom carbon fiber plate and mounted two where the heat controls where and two where the radio went. I am thinking about moving some things around when I get home again. I have the JDM lower console also. So I have thought about moving them down there but I dont know how well I will be able to see them there.
Old Oct 5, 2006 | 01:44 PM
9civichatch3's Avatar
NICE GUY
i went with AutoMeter "Z" series.
Old Oct 5, 2006 | 02:42 PM
Sprockets's Avatar
You'll get a million different answers to these questions. How much are you willing to spend? What color do you want? Do you want 52mm or 60mm? Some people have luck with AutoMeter, but I think (at least their boost gauges) are garbage. You don't have to spend a fortune to get good Japanese gauges. Defi D-Gauges were pretty reasonable, but have been replaced with different color gauges.
Buzzbomb, nice pic, but show 'em a pic with your lights turned on!
Old Oct 5, 2006 | 03:25 PM
Got_soy's Avatar
Default Re: Which Gauges? (Mr. HYDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. HYDE &raquo;</TD></TR><TR><TD CLASS="quote">
I remember that dash from the track vid. IM temped to try something like that with my ef
Old Oct 5, 2006 | 05:25 PM
Tony the Tiger's Avatar
For gauges that you want a precise readout, Japanese gauges like Defi or Greddy are hard to beat. I've tried using Autometer, SW and VDO electrical water temp gauges, but none of them could give a clean readout for the regions between 185 deg F and 195 deg F. It's always a short sweep electrical gauge and very slow acting as well.
I have SW gauges for oil temp and boost; water temp and EGT are Greddy gauges, and AFR is an AEM wideband for the Integra:
Here are some Defi D-gauges for my other car:
Old Oct 5, 2006 | 07:10 PM
A.E Motoring's Avatar
Default Re: Which Gauges? (Tony the Tiger)
im pretty content with my autometer carbon gauges
Old Oct 6, 2006 | 06:30 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj9046 &raquo;</TD></TR><TR><TD CLASS="quote">buzz bomb where did you get that mount ?</TD></TR></TABLE>
I got the base off of ebay. It was all plastic that had a large swivel base molded to the bottom that I cut off so it would sit closer to the steering column. I then drilled a hole in the bottom for a screw and used a rubber bushing cut down for padding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets &raquo;</TD></TR><TR><TD CLASS="quote">Buzzbomb, nice pic, but show 'em a pic with your lights turned on!
Ha ha, alright.
Old Oct 6, 2006 | 06:40 AM
B18Flip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
i miss my d-gauges..too bad they're discontinued. Check out the blue racer series, seems pretty reasonable priced
Old Oct 6, 2006 | 08:46 AM
gunmetalej's Avatar
Default Re: Which Gauges? (B18Flip)
Im putting my blue racer defi gauges in on monday so i will post pics!! stay tuned
Old Oct 6, 2006 | 11:01 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Which Gauges? (gunmetalej)
If you plan on tuning your car yourself or like to know the exact read for crucial guages like boost egt ect I would highly suggest 2 5/8. When trying tune and if your running enough boost with a decent sized snail looking at your boostgauge, EGT and then the tach road AFR ect. It all goes by really fast and tiny #s are quite hard to read. When My next setup will have a 2 5/8 boost gauge, EGT and Im not sure of the third gauge Im going to run but it will prolly be 2 5/8 as well.
got-vtec?
Jul 20, 2011 11:06 AM
JDM_EH2
Jan 12, 2007 09:52 PM
p1ccoloz
Aug 3, 2004 12:21 PM
TwistedSI
21
Jun 3, 2003 04:39 AM
