Oil Pump ?
Application: B16A1 Swaped into a CRX
We are building a fully built turbo engine and putting in a new oil pump. What year / model / make do we order the pump for?
I did see the KMS has an upgrade but not sure if that is worth the cash.
Thanks again, J
Thanks again, J
most folks tend to lean toward the ITR oil pump. any year Integra Type R will work, 1997-2001.
Acura Carland is a great place to find OEM parts cheaper than at dealerships. there may be other places i don't know about, but i've had nothing but good experiences dealing with carland.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WVTURBOCRX »</TD></TR><TR><TD CLASS="quote">Thanks for not answering my question. That's why your avitar is a donkey
Wow...
I guess I have to get detailed.From what I have been able to tell there are two pumps being offered by Honda for a B series now.OBD1 & OBD2.The difference is the lower belt cover fitment.All the parts are vtec spec now (increased spring pressure). The part number for a OBD1 (pre 1996) is 15100-pr3-024 which should be the one you need if it still has the original cover (no crank sensor).Endyn sells a modified oem pump that people have had good luck with.That's the only one I would recommend other than just a stock oem unit.The only problem with Honda pumps is gear breakage and it can happen to a new one or 200k.The best guess on that issue is harmonics.Prodrive makes a improved gear but those have broken also.
I hope my answer was complete enough for you.
</TD></TR></TABLE>Wow...
