freeway pulls
Old Oct 3, 2006 | 06:50 PM
filipevti's Avatar
Default freeway pulls
hello ppl can u help me in a stupid question that i have , is that can a turboed(b18c5 stock internals)car make long trips????and another one can the same car pull over 140mph in a freeway without causing any king of harm to the engine
thanks
Old Oct 3, 2006 | 06:52 PM
EK FLY's Avatar
Default Re: freeway pulls (filipevti)
lol at 140 that means 5th gear that would be engine carnage if u dont want to try it ,let me have it . i'll try it and i will let u know
Old Oct 3, 2006 | 06:54 PM
85's Avatar
85
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filipevti &raquo;</TD></TR><TR><TD CLASS="quote">hello ppl can u help me in a stupid question that i have , is that can a turboed(b18c5 stock internals)car make long trips????and another one can the same car pull over 140mph in a freeway without causing any king of harm to the engine
thanks </TD></TR></TABLE>
First off, the money you could save on the C5 could go into internals on a C1 or even an LS. The High compression of the C5 would seem like a wast of money to me. Not to mention i dont think you could get much tuning out of the high compression.
Old Oct 3, 2006 | 06:55 PM
slodc2's Avatar
Default Re: freeway pulls (super-hatch)
i strongly advise u not to do that haha
Old Oct 3, 2006 | 06:57 PM
bigbadboy's Avatar
first of thats not what he was asking^^. and to answer your question yes you can make long trips do watever you want as long as you get it tuned right and not push the power levels to high unless your going to replace internals.
Old Oct 3, 2006 | 07:02 PM
filipevti's Avatar
thanks for helping me in my question yah at 8psi of boost t3t4e 57trim .63ar
Old Oct 3, 2006 | 07:05 PM
85's Avatar
85
Default Re: (bigbadboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">first of thats not what he was asking^^. and to answer your question yes you can make long trips do watever you want as long as you get it tuned right and not push the power levels to high unless your going to replace internals.</TD></TR></TABLE>
your right my bad
filipevti's Avatar
and my goal is 230whp because its a daily driven car
bigbadboy's Avatar
should be fine just get a good tune on her and enjoy
Old Oct 3, 2006 | 07:08 PM
filipevti's Avatar
thanks a lot one more time ppl of ht this forums is awsome than u all
Old Oct 3, 2006 | 08:26 PM
ccivic's Avatar
Default Re: (filipevti)
Better be tuned correctly and you need to have adequate cooling. Overheating and tuning errors exponentially multiply during 5th gear pulls -- too many horror stories
Old Oct 3, 2006 | 08:41 PM
SovXietday's Avatar
Default Re: (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">Better be tuned correctly and you need to have adequate cooling. Overheating and tuning errors exponentially multiply during 5th gear pulls -- too many horror stories </TD></TR></TABLE>
Hell, on a public road, 3rd gear pulls are more than enough.
I avoid 5th gear pulls like the plague, too much heat.
Old Oct 3, 2006 | 08:54 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch &raquo;</TD></TR><TR><TD CLASS="quote">lol at 140 that means 5th gear that would be engine carnage</TD></TR></TABLE>
Ahh, the plus side of LS gears haha.....140 is still in 4th gear
Old Oct 3, 2006 | 09:01 PM
turbotime's Avatar
swap in an ls final drive or get an egt so you can watch whats goin on during the pull
you will see egts climb fast in 5th lol
Old Oct 3, 2006 | 09:39 PM
Armed Ferret's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filipevti &raquo;</TD></TR><TR><TD CLASS="quote">and my goal is 230whp because its a daily driven car
i think you'll find with 8 psi on an ITR engine (provided it's tuned properly) you'll be seeing that plus some.
just stay away from those 5th gear pulls like the others have said. bad juju.
Old Oct 3, 2006 | 10:19 PM
triple_s1x's Avatar
Default Re: (Armed Ferret)
5th gear pulls can be done, its all in your tuning and cooling.
Old Oct 4, 2006 | 04:34 AM
85's Avatar
85
Default Re: (triple_s1x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by triple_s1x &raquo;</TD></TR><TR><TD CLASS="quote">5th gear pulls can be done, its all in your tuning and cooling. </TD></TR></TABLE>
If you got your car tuned on E85 which you should see available more and more around the US at the pump, you could do 5th gear pulls all day! A lot of guys are using it on their drift cars right now to help them stay cool. Even tuning on E10 would help a little.
Old Oct 4, 2006 | 05:28 AM
96 GSR-T's Avatar
Default Re: (hks85)
Save a life, stay out of 5th gear.
Old Oct 4, 2006 | 06:13 AM
playahwitgame's Avatar
Default Re: (96 GSR-T)
yea i only boost in 5th gear at most 3seconds. i get too scared. but if im boosting 5th, im just trying to pass a car or something and within 3 -4 seconds, im good
Old Oct 4, 2006 | 06:24 AM
TrueNorthStar's Avatar
I wonder what could be done to make running a constant 150+mph possible in our little hondas.
Not that I would do it here, but while I was in Germany, I averaged ~160mph (255-265kph) the whole time I was on the autobahn and I was still getting passed!
Taller gears, Oil cooler, Trans cooler and some aerodynamics work?
Old Oct 4, 2006 | 06:45 AM
purpleh22's Avatar
Default Re: (TrueNorthStar)
With a good tune the engine should hold up better than you would, if you got clocked @ 140 mph.
Old Oct 4, 2006 | 08:49 AM
filipevti's Avatar
lolo thanks ppl
Old Oct 4, 2006 | 10:26 AM
turbotime's Avatar
i think the only real way to get 5th gear good is have your tuner street tune 5th cause your entering areas of the map you would never see on a dyno
EGT, wideband o2, and a tuner willing to trust you driving 140+mph and then MAYBE it would prolly be safe (tune wise!)
Old Oct 4, 2006 | 10:29 AM
EJ1 wilcox's Avatar
Default Re: (turbotime)
This is why I invested in an EGT gauge for my current setup.
Just keep an eye on those EGTs and let off the gas before it gets too hot.
I've done many long pulls in 5th gear without any harm to the engine.
Old Oct 4, 2006 | 10:46 AM
eddie_ek's Avatar
You can turbo a type r but you have to keep very low boost beacuse of the high compresion so it does not justify the money you spend on the turbo set up and if you do have turbo you can drive on the hyway no problem turbo only activate at half or more throttle I do 80mph with no boost.
