what fuelpump do i need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">I would say a Walbro 255lph fuel pump will be sufficient for your power goals.</TD></TR></TABLE>
and what about a 190lph?
and are there any negatives about the hp version? because its cheaper?
just get the 255lph...it will be good for u now and when u upgrade in the future...just check your fuel pressure once you put it in...they like to bump your fuel pressure up about 10psi or so...so i would get an adjustable fpr or that fuel pressure modifier from B&M also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr »</TD></TR><TR><TD CLASS="quote">I would go with the standard 255 lph, instead of the hp. Especially if you are using stock fuel rail/regulator/return line.</TD></TR></TABLE>
i have got a better regulator and a stock return line. but why would i need a different fuel rail???
is it gonna explode????
Propulsion
Nov 24, 2003 09:38 AM
