ran my si with msd it ran fine for a few and now i have no spark, help?????
i have a b16 si turbo with an msd sci & ex. coil, it ran fine for a few runs and it just died, i tested the plugs and there fine, but im getting no spark. i disconnected the msd and installed my stock ignition and it still just cranks, cranks and cranks.
i need some help??????
Re: ran my si with msd it ran fine for a few and now i have no spark, help????? (Dollar_bill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dollar_bill »</TD></TR><TR><TD CLASS="quote">you might have a bad igniter, hope this helps.good luck</TD></TR></TABLE>
If he is running a MSD box and an external coil then the igniter would matter.... because the box and coil take over the igniters job
The blaster SS coils are junk. I have personally had 5 of them go bad on me with in a couple of weeks so I upgraded to the Digital 7 and HVCII coil and haven’t had a problem sense.
Re: ran my si with msd it ran fine for a few and now i have no spark, help????? (BoostedEG6)
but i installed the stock in. coil and it still doesnt start
Re: ran my si with msd it ran fine for a few and now i have no spark, help????? (1baddcivicsi)
ok so you disconnected the external coil and box, wired the igniter back up and made sure everything was in the correct location and all the distributor wires where connected?
Have you tried any other distributors?
stock distributor, wires are correct, and 1 degree cooler ngk plugs have been installed
also checked my ign. coil fuse and that is good to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">
You bypass the ignitor when you use a msd?
Re: ran my si with msd it ran fine for a few and now i have no spark, help????? (DRAGLS)
yes, i had my msd running fine, then i turbo'd it, and ran good for a few tunes, then it just died while we were getting on it. but the msd worked great before. i installed the stock internal coil and it still doesnt start.
How do you bypass the ignitor? I have a msd installed on my integra and I didn't see anywhere on the manual saying how to bypass it. So mine is still hooked up.
i believe by taking out the stock in. coil, installing the + and - wires to the msd, is that what u are getting at???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddcivicsi »</TD></TR><TR><TD CLASS="quote">i believe by taking out the stock in. coil, installing the + and - wires to the msd, is that what u are getting at???</TD></TR></TABLE>
Thats not bypassing the ignitor.
btw- try a different ignitor that is most likely your problem.
yes when you install the external coil you take the + and - wires to the external coil that bypass' the igniter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">yes when you install the external coil you take the + and - wires to the external coil that bypass' the igniter</TD></TR></TABLE>
Your kidding right?
I gotta ask, do you even know what&where the ignitor is?
Your kidding right?
actually i thought that the igniter, was the in. coil??? i dunno, now that u told me what it was, how do i bypass the ingiter??
A standalone system will let you bypass it.$$$$
No, the ignitor is the little box at the bottom with 4 wires hooked up to it.
i have an AEM EMS, that is what you were talking about
i have not come acrossed that on my ems but im sure i can find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS »</TD></TR><TR><TD CLASS="quote">
Your kidding right?
I gotta ask, do you even know what&where the ignitor is?</TD></TR></TABLE>
yes I know what it is..... I had a brain fart .. bear with me its 2am here in baghdad
Your kidding right?
Sorry dude
My brother just came back from there a week ago.
Sorry dude
i'd be willing to bet that its my igniter thats bad, becuase my msd and my stock ignition are both not firing. but i think the aem is a couple hundred $
most likely the ignitior. i had a car do that same thing while tuning. replacing the ignitor, the car started right up
Re: ran my si with msd it ran fine for a few and now i have no spark, help????? (boosted k20)
u know how much $ the igniter costs??
