intercooler piping doesnt fit?!?!
Ok to start off Its a 94 civic hatch with a gsr swap. I recently purchased a log manifold from a reputable sponsor also with a 2.5 flare to 3inch dp .anyhow im having fitment issues with my old IC piping the throttle body side fits fine ofcourse but the compressor (turbo) side doesnt. the downpipes bend ,along with the ac lines make it impossible to fit the piping up to meet with the turbo's coupler. the only solution i could see was to remove the AC lines and it MIGHT clear but thats rediculous considering i payed extra for an a/c comp DP and got a log mani just for this reason of to not have fitment issues. At first i was mad cause the way the wastegate was placed it hit the ac lines also but what made worse there as well is it also hit the ps bracket so i have to knotch it if i want ps. It seems to me even tho its listed as ac/ps compatible it is far from that . Anyhow even tho im ranting the purpose of this post is to see if anyone else ran across these problems and what tehy're solutions where, help is much appreciated , thanks daniel
this may just be me, but i cant see how you can buy a IC piping kit and expect it to directly bolt up. Unless you run the exact manifold, turbo, IC, and motor as it was made for I cant really see it being a direct bolt up. Some people are going to have IC's with longer or shorter end tanks, manifolds that drop the turbo a bit lower, or turbos that are a bit bigger and wont allow piping to line up. Not trying to come off strong, but i just dont understand how a specific intercooler kit will fit per say "a b18c turbo with log mani" where most people are not running the same setup
and once again ur not reading what im typing, the issue isnt with the charge piping its with the manifold, the charge piping used to fit with my old drag manifold which is still a log style, the new LOG manifold i have with the 3inch a/c downpipe will not alow ANY kind of charge piping in there atleast with the ac in. The dp bend is to radical, anyhow ill get pics asap prolly tommorrow cause my cheap *** has to borrow a camera
i did not make the downpipe, nor do i have a welder to fix it. i need to take pics to show what the prob is, i never new installing an ac/ps comp log would be this rediculous , might as well got a ramhorn
Modified by Project99EK at 5:26 AM 10/8/2006
Here are some pictures to show what i mean
Just click the thumbnails for a bigger pic. Theres my attempt at getting the view, if u guys need other pics lemme know.
By the way the charge piping has to go over or clear the downpipe to get to the intercooler cause remember its an a/c manifold so the dp is on the driver side.
Modified by Project99EK at 5:43 AM 10/8/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project99EK »</TD></TR><TR><TD CLASS="quote">
Get a new downpipe.
</TD></TR></TABLE>Get a new downpipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project99EK »</TD></TR><TR><TD CLASS="quote">maybe if i get a new dp for free since this was sold as a kit ac/ps compatible
but did the fabricator know what turbo you were running? which way you were clocking the compressor? those are factors that are out of the fabber's hands
</TD></TR></TABLE>but did the fabricator know what turbo you were running? which way you were clocking the compressor? those are factors that are out of the fabber's hands
umm yes considering its like the oem turbo people run t3/t04 and besides that u cant clock the compressor any other way to make it fit
blackccoupe
Aug 9, 2011 06:00 PM
