Built motor question.... ls-t then later going lsvtec-t?
Hey guys just trying to find out the best way to budget my money... .i was thinking about building up the bottom end of an ls engine, while pretty much keeping the head stock, the reason being is that in future i want to go with a ls-vtec combo...
now my question is...
if i put
forged internals (rod, pistons and if i sleeve it or bore it out)
will i still be able to add a vtec head later and still use these same parts?
can i use the same chrome pro fmu? and tune with it aswell? what are the problems with doing this? will the turbo setup fit the same after a vtec conversion?
basically if i build the bottom end for a future project but build the turbo to fit the ls... will it still work with the lsvtec in the future? And what kind of problems am i looking at when i try to add the vtec head?
thanks in advance for ANY help you guys can give me thanks!!!
btw i accidentally posted this in integra forum... so if your a mod could you please remove it? thanks!!!
if i put
Re: Built motor question.... ls-t then later going lsvtec-t? (aznegg)
if you plan on running a vtec head later down the road. be sure to get Vtec pistons in your bottom end. they have a larger valve relief for the vtec heads.
gearhead313
34
04-19-2007 04:34 AM
EliteIntegra
05-02-2002 12:45 PM
