thoughts on this engine setup
Old Jul 24, 2009 | 03:46 AM
AJxr's Avatar
Default thoughts on this engine setup
assembling this today, just wanted to get some opinions from you guys.
im expecting a lot of hate haha.
b16a head, 01 itr cams
b18b1 block, 81mm
b18b1 crank
b16 tuner toys rods
81mm forged 3.5cc dome pistons (this setup will be 8.6:1 according to zeal)
ls rod bearings
now it has the same displacement as an ls, and the rod stroke ratio goes from 1.54:1 to 1.51:1 which aside from compression, is the only change that will be from using the b16 rods.
the only reason i am putting this together was that i planned to build a b16 but i can just toss this stuff in an ls block/crank and gain some displacement without buying all new parts.
also the dimensions of the b16 rod and an ls rod are EXACTLY the same ASIDE from length, the wide and journals are the same.
the b16 rods are 3mm shorter then the ls rods. stuff im sure all of you know but ive never seen anyone actually do this... and no i wasnt set out to make this build, im just using whats laying around at my house.
Old Jul 24, 2009 | 10:55 AM
intense4thgen's Avatar
Default Re: thoughts on this engine setup
someone correct me if im wrong but i think b16 rods in a ls block will seriously reduce compression.
Old Jul 24, 2009 | 12:44 PM
AJxr's Avatar
yup. those pistons on the ls rods would be 11.3:1 but with the b16 rods it will be 8.6:1. i didnt set out to build this, just a bunch of parts i have laying around that im putting together.
Old Jul 24, 2009 | 05:58 PM
blackeg's Avatar
lol here are my thoughts.
put it together we are all going to the valley on wed lol. still have the stock b16 springs/retainers in it?
Old Jul 24, 2009 | 06:01 PM
AJxr's Avatar
YES! and btw the bottom end is together minus the oil pump, water pump. head is on but yes stock springs retainers heh. valley on wed is a possibility if it doesnt grenade on startup tomorrow haha
Old Jul 24, 2009 | 06:04 PM
Honda Bull's Avatar
Well... it's gonna suck *** under 3000 rpm compared to most builds - I say this 100% regarding daily driving duties and not WOT/racing. But go ahead and see what it'll do. lol
Old Jul 24, 2009 | 06:08 PM
AJxr's Avatar
thats perfect, cause im at 3400 at 60mph anyway haha
Old Jul 25, 2009 | 03:07 PM
AJxr's Avatar
update. everything went together great and it runs. going to get some new oil for it then some test drives/street tuning.
CTR_B
Oct 17, 2008 04:19 PM
Suck my DX
26
Jan 28, 2007 02:47 PM
teefunk01
May 12, 2005 02:29 PM
joey1320
Dec 7, 2004 09:10 AM
JDMlyfestyle
Jul 3, 2004 04:50 PM
