turbo d16 help and suggestions.
Old Jul 17, 2009 | 09:39 AM
tylergrae's Avatar
Default turbo d16 help and suggestions.
hey i have a d16z6 with 130k miles on it. id really like to boost it on stock internals but im not sure sure it will last. i REALLY want it to be my daily driver after i install a turbo still.
it would be a custom turbo kit. my friend is giving me a little turbo off a twin turbo 3000gt and side mount intercooler id just need to buy everything else.
i'd really love to hear some suggestions and opinions on this. i'd also like to know what anyone thinks this would cost (tuning included).
Old Jul 17, 2009 | 09:54 PM
95civhb's Avatar
Default Re: turbo d16 help and suggestions.
it's a td04-13g ... it's small... flows about 360cfm... would make for quick spool...
sidemounts work, but front mounts are generally more efficient...
Do a compression test prior to buying this stuff to see what shape the motor is in, and go from there...
if you don't want to build the bottom end, this turbo will work ok for you... If you want to throw a set of vitara's and custom rods in there, then dream big
Old Jul 18, 2009 | 08:29 AM
tylergrae's Avatar
well the sidemount actually comes from a sr20det motor. my radiator is quite small and theres enough room to put the intercooler NEXT to the radiator for a little front mount. that is what i was PLANNING on doing. but thatnks for the help. i really just dont want to do this and then have my motor blow in 2 months b.c theres alot of miles on it. reliability is a big factor.
Old Jul 18, 2009 | 03:25 PM
Adriano's Avatar
Just make sure your motor is still fine, dont worry about the milage. I just boosted my 99 dx d16 non-vtec and it made 196hp/190ft/lb tq bone stock, I have a 14b turbo @ 11psi.
Adriano
Old Jul 18, 2009 | 08:45 PM
95civhb's Avatar
do a compression test... don't worry about the miles on it, as long as the compression test comes back fine...
that's what I would do first, and then go from there...
If you are just looking for a bit of boost for a fun ride, that turbo and SMIC will be fine... make sure you get a good tune..
just remember.. boost is addictive.. buy another block and start building it ! :D
Old Jul 20, 2009 | 03:51 PM
civ97's Avatar
What should the numbers read from a compression test on a d16y8
Old Aug 9, 2009 | 09:03 PM
trevathan's Avatar
i have a d16 jdm 1.6l with and com cam skun 2 throttle body 70 mm and a skun intake manfiold lol cant right tonight and coldair intake and i 4 in to 2 hearder just wanting to see what i can do next with out going to a spelling class to get some more power out of my ride and yes i got a full msd set up on this ride lol you all non belivers it can be done
Schleudertrauma
Sep 13, 2007 07:00 AM
white ej2
16
Oct 8, 2006 10:16 AM
Gsr94black
Nov 15, 2004 09:19 PM
Curtisbeef
Oct 19, 2004 07:58 AM
allmtr
Apr 9, 2002 07:49 PM
