what should i gap my plugs to?
I know this is a newb ? but im just lookin for a gap i should set my ngk 11's to. .03" is what i have found but not sure if thats approperate. heres my setup:
t3/t4e 9psi
440injectors
255pump
crome pro
n all the other good ****
thanks
t3/t4e 9psi
440injectors
255pump
crome pro
thanks
Re: what should i gap my plugs to?
NGK BKR7E-11 (what i got) gapped to .030" and work my way from there. check I am my tuner. i will be doin it myself.
i run bkr7e and i set gap to around 22, you will get away with a much wider gap due to the much lower psi and total power your making. try 28-30 that should do you fine.
