Ceramic coating
Old Jul 20, 2009 | 11:38 AM
jetspeedz's Avatar
Default Ceramic coating
Guys i have the option to ceramic coat the manifold/turbo exhaust housing/downpipe on my peakboost turbo kit with manifold that retains the ac & ps.
Do you think the price tag is worth it and will it make that much of a difference. I have searched and nothing came up under ceramic coating.
thanks
Old Jul 20, 2009 | 11:52 AM
Turbo-LS's Avatar
Default Re: Ceramic coating
keeps engine bay temps down, stops **** from rusting and helps spool turbo by keeping heat in the system . its worth it
Old Jul 20, 2009 | 12:00 PM
jetspeedz's Avatar
thanks for the response. its going to cost an additional $350 for the coating you guys think its worth it then ill do it. Ive always used the spray can coats in the past but they chipped as i would expect after a long time but i don't want to cut any shortcuts with this setup if it really does make a difference.
Old Jul 20, 2009 | 01:53 PM
smoovy's Avatar
please do yourself a favor and contact Olympic coatings. your in socal, the cost to thermal coat/ceramic coat **** is cheap. $350 is steep, for a thermal barrier coating if you do it before you run the manifold on any car, they will give a lifetime warranty on the coating, if you run it on your car and then coat it, it's a 3 year warranty. I've had mine for 5 years and counting. olycoatings.com.
Old Jul 20, 2009 | 02:21 PM
jetspeedz's Avatar
Thanks for the heads up. i will see what they can do. thanks
shutupnshift04
Dec 19, 2005 02:11 AM
94hondaLS
Feb 6, 2003 08:42 AM
01ITR#700
Jan 11, 2003 04:38 AM
boost killz
Dec 9, 2001 07:49 AM
